Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Can't Remove Brake Drum
Old Jul 14, 2007 | 06:34 PM
mike s.'s Avatar
mike s.
Hi, I'm new here; glad to have found this place.
I have a basic 4-cyl 2005 Escape, and I want to check my rear brakes. I replaced the front pads recently when they went to metal at 34K miles. I don't expect the rear shoes to have gone bad yet, but I'd like to see for myself. My problem is, I can't get the drums off! I've done dozens of brake jobs in the past, so I'm not doing anything dumb like leaving the hand brake on, but the drums just won't come off! I am assuming I need to back off the hand brake adjustment (since Ford recently adjusted the tension under warranty) but don't know how to do it. I have, of course, removed the little retainer clips on the lugs... Frustrated. Somebody, please save my sanity!
Old Jul 14, 2007 | 06:36 PM
ford390gashog's Avatar
ford390gashog
Hummm? Do those drums have 2 threaded holes on the flange? You can insert 2 5/16'' bolts to remove them
Old Jul 14, 2007 | 07:06 PM
mike s.'s Avatar
mike s.
Nope, no threaded holes.
Old Jul 14, 2007 | 07:21 PM
justo2000_2000's Avatar
justo2000_2000
Have you tried tapping the drum with a big hammer between the studs? That normally breaks them loose for me.
Old Jul 14, 2007 | 09:00 PM
mike s.'s Avatar
mike s.
Oh yes. Tapping, banging, prying from the bacik, 2 claw hammers, 5-lb mallet w/ crowbar, you name it. It feels like it's still bound somehow, like I need to disconnect something, because it won't even budge to one side a little after prying on it. I'm wondering if I have to disconnect the huge bolt on the back inside the ABS system, since it feels so solid.
Old Jul 15, 2007 | 10:41 PM
5_labsownus's Avatar
5_labsownus
Some times you need to get a bigger hammer and take a good swing at the drums. They rust around the hub and stick very well!
Old Jul 16, 2007 | 07:26 AM
mike s.'s Avatar
mike s.
The car is fairly new, and there is no obvious rust around the drum or hub. It feels like it is being held. How do I back off the shoes? There is no port behind the drum to access one of those star wheel adjusters.
Old Jul 16, 2007 | 09:23 AM
merlynr's Avatar
merlynr
Make sure there isn't 2 big flat screw heads that hold drum to axle like my daughters ZX2 Escort. Required a screw hammer(can't rremember correct name) to get them loose.
Old Jul 16, 2007 | 02:34 PM
mike s.'s Avatar
mike s.
Nope, nothing like that on there. It's a mystery. It is an ABS system, so I'm wondering if that has something to do with it.
Old Jul 16, 2007 | 02:41 PM
merlynr's Avatar
merlynr
The ZX2 has hand brake adjuster atthe base of brake handle where the cable is attached. I just removed a little cover by popping it off and exposing the adjuster.
Old Jul 16, 2007 | 10:12 PM
mike s.'s Avatar
mike s.
Sounds good. No easy access panel on the Escape, though. Will look into it.
Old Jul 17, 2007 | 08:34 AM
merlynr's Avatar
merlynr
You might be able to delay this maintenance for a while. I change rears about one time for every 3-4 times for fronts.
Old Jul 17, 2007 | 12:43 PM
Skweeker's Avatar
Skweeker
If you have never adjusted the rear shoes then they should not be holding the drum on.
I just replaced my second set of pads and rotors on the wife's 2003 Escape at 56,000 miles. Vehicle has about 62,000 miles now.
Old Jul 17, 2007 | 01:23 PM
mike s.'s Avatar
mike s.
Ford recently adjusted the hand brake, so I think that could be the problem. Sooner or later, I'll have to get those drums off.
