engine selection please help
Old Feb 12, 2002 | 11:19 PM
wolfface's Avatar
wolfface
I'm looking for some advice on up-grading my engine. I'm looking for a light powerful engine. I now have a 300 6cyl, I would like a v-8 that is about 300-400 hp. I would like to know the weight differences of the 302, 351, and 460. I am not sure what will fit my T-18 tranny.
Any advice or opinions would be greatly apreciated.
1981 F250
4" rancho lift
rs 9000
315/75r16 goodyear wrangler mtr's
chrome rock crawlers
all brute force universals
a dying 300 6cyl
dana 44 ifs
dana 60 ( that needs to be locked)
t-18 4 speed
1345 borg wagner transfer case
GMC- great mechanics car
GMC- get my creditcard
FORD- for off road dominance
Old Feb 12, 2002 | 11:43 PM
Ratsmoker's Avatar
Ratsmoker
Go to http://www.fomoco.com and in their text book it displays the weights of most ford engines. The 460 isn't there but the 429 will weigh almost the same.
Old Feb 13, 2002 | 07:17 AM
shazam's Avatar
shazam
What you over looked the 400 ???
Old Feb 13, 2002 | 11:09 PM
wolfface's Avatar
wolfface
I haven't found many 400's for sale, but I have found many 302's and 351's.
800 hp is amazing, talk about get in, shut up, and hold on ( or make sure your head is firmly against the head rest.) :-staun
Old Feb 14, 2002 | 07:46 AM
slikness's Avatar
slikness
BTW, does anyone know what the 300 I6 weighs??
Old Feb 14, 2002 | 10:21 AM
rc351w's Avatar
rc351w
Wolfface,
Both the 302 and 351W will fit your tranny, to do the swap you'll need the motor mount perches from a donor truck, a new crossover pipe for the exhaust and a rad for a 302/351W. These are the same things you'd have to change for any V8 swap but you won't need a different tranny if you go with a 302 or 351W. Both the 302 and 351W are respectable motors capable of producing 300+ HP. I would go with the 315W though because it will produce the power your looking for without sacrificinig low end torque.
RCC
Old Feb 14, 2002 | 07:19 PM
canzus's Avatar
canzus
>Wolfface,
>302 or 351W.
You'll also need to move the trans crossmember
forward about 4". Which'll mean new driveshafts
front and rear.
You're still better off using the 300cid L6 than
changing to a V8, Just go to
www.cliffordperformance.com, they'll have
all the parts you need for a stout 6...
Steve & the Rockette
Old Feb 14, 2002 | 08:28 PM
buckford's Avatar
buckford
you do not have to move the trans cross member foward for the 302 and the 351w, i did this swap in my 1983 f-150 4x4, it had a 300 in it i put in a 302.
Old Feb 14, 2002 | 09:50 PM
Superdave's Avatar
Superdave
slikness, The 300 - 6 weighs around 385 pounds with factory intake and no accessories.
Old Feb 15, 2002 | 05:38 PM
slikness's Avatar
slikness
Thanks, Super Dave, man I could swear that beast weighed as much as my 351W when I pulled it out...
I also agree that you do not need to move your transmission cross member, I did the swap on my '82 2wd and did not have to change anything from the flexplate back.
Old Feb 16, 2002 | 12:05 AM
lvstang's Avatar
lvstang
Old Feb 16, 2002 | 02:53 PM
Dmaas17's Avatar
Dmaas17
If you have a budget the size of the national debt, my dream engine is a Stroked 351w that displaces 427 cubic inches with a set of stage 2 trickflow aluminum heads. it puts out about 400hp and 450 flbs torque with regular unleaded that weighs the same as a cast iron headed 302 and then there is still the option of putting a supercharger on it.........(wake up) oh back to reality.......
but if you do have an unlimited budget you could look into this there are several companies that you could look up on the net, D.S.S. motorsports is one company......
