leveler springs
Old Jul 14, 2007 | 01:26 PM
JR67Ford's Avatar
JR67Ford
leveler springs
I got a 96 F-150 302,auto I want to put leveler springs on it to bring up the front end .can you run 33's with just a leveler spring? or am I going to have to go with a 4 inch lift???
Old Jul 14, 2007 | 01:40 PM
lostin90s's Avatar
lostin90s
If you don't go off flat road that includes pulling into parking lots . You can fit 33" .
Well you can fit em but 1 wrong twist while turning and you might do some damage . I have ran them with Rancos 3" lift just fine and on stock truck . I cut bumper/fender for clearance. Stick with 32' tires or waitfor $ to lift. Good luck
Old Jul 14, 2007 | 07:08 PM
Phillip Guidry's Avatar
Phillip Guidry
I have rann 31's and P265/75's on a 88 F150 2wd with no problems.Right now I have a 3" difference between front and rear.......front being lower by 3" when measured from top of tire to the wheel well moulding. Someone suggested that I needed to replace the factory springs with factory springs to bring the difference to within 1" because they where "sagging". I am not sure that my front actually sag's ......the other trucks around town seem to have the same stance ....allthough they seem to be running the P235's ? I want to change out the front coils when I do the radius bushings in the near future...but can't decide on aftermarket 2" over coils or a set of CC822 or CC824 standard Moog/TRW coils ?
Forddiesel11
Oct 15, 2012 09:31 PM
armydude
Sep 27, 2011 06:21 PM
mattsautobody442
2004 - 2008 F150
Jun 14, 2011 09:39 PM
AFShooter
Feb 15, 2004 05:41 PM
92Custom
Sep 4, 2002 11:48 PM
