Coolant Leak
Old Jul 14, 2007 | 12:37 PM
azu's Avatar
azu
Coolant Leak
I've had this leak for close to a year and isn't really a big deal as I only lose about a cup month. I initially thought it to be a waterpump gasket leak as the leak was at the bottom end of the water pump gasket on the passenger side.Today I don't think this is the case. It appears to be coming from just a few inches below the water pump gasket and actually from the block. The part of the block has a large freeze plug and if you follow the lower block towards the front of the truck it appears to be coming from the corner of the block. Probably a gasket there leaking. What gasket is this and how do I go about replacing this? I might not bother yet as the leak is very minimal.
2000 3.0 FF
Old Jul 14, 2007 | 12:54 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
There is a gasket between the water pump and the front cover and another one between the front cover and the block. It's more likely that the water pump gasket is leaking than the front cover.
Old Jul 16, 2007 | 11:55 AM
azu's Avatar
azu
The spot that appears to leak is where the side of the engine meets the front. Would that be a head gasket under there?
I'll see if I can post a picture. That will help out more.
Old Jul 16, 2007 | 02:50 PM
cookie88's Avatar
cookie88
FTE Emeritus
Is the truck running ok? If the head gasket is puking coolant it would not be running right.....but it may well be the front cover gasket.
A picture definitely would help.
Old Jul 16, 2007 | 03:18 PM
azu's Avatar
azu
Truck running great! When I get a chance I'll post a photo. Thanks!
Old Jul 16, 2007 | 07:56 PM
azu's Avatar
azu
Well after looking at it again it may be water pump gasket. Does it actually go that far down to the bottom of the block? Here is a picture.
Click on photo for bigger one. Not the best pic but that was the best I could get.
