General Diesel Discussion
Glow plug controller
Old Jul 14, 2007 | 12:21 PM
Lionbacker's Avatar
Lionbacker
I have searched my manual twice and can find no information on the Glow plug control circuit. I have an 1987 F250 and the wait to start light comes on and stays on. My truck will only start when using starting fluid. I don't know what to replace. Any help will be appreciated.
I'm wondering if I can't just trace the line to the glow plugs and install a hold-to-power switch to power the Glow plugs.
Old Jul 14, 2007 | 02:41 PM
nlemerise's Avatar
nlemerise
I've got to assume you are in Antartica if you need the glowplug system to start the truck this time of the year . OK, first chase the penquins away from the front of the truck. Find the relay for the glow plugs
and jump the big posts with a screwdriver for about 30 seconds or so with the key on. Then try to start her up...if she starts without the smoke you have found your problem...a new glow plug relay is your answer. If it doesn't make any difference you'll need to ohm out the glow plugs through their harness.
ON EDIT: I just now noticed that you have an `87....you might want to post this to that group...
Old Jul 14, 2007 | 04:52 PM
Lionbacker's Avatar
Lionbacker
Thanks, Neal. No penguins here in Tennessee. 94 degrees F.
Isn't there more than a glow plug relay to control the circuit? My "wait to start" light comes on and stays on. Even when I drive 100's of miles, the light is still on. I just replaced all the glow plugs because I thought that was causing the failure-to-start problem. Soon after I did that, the "wait to start" light started staying on, but not immediately after replacing them.
Old Jul 14, 2007 | 07:00 PM
nlemerise's Avatar
nlemerise
I have no idea how the circuit is set up on a 1987...On the newer PSD's I can tell you that all your key does is send a low amp signal to the relay which closes a contactor inside and lets high-amperage to go from the battery to the glow plugs. On the newer trucks, the "wait to start" light is independent of the glow plugs. When you turn the key the PCM uses a few sensors (temp, barometric pressure) and decides how long the glow plugs should be on, irrespective of how long the WTS light is on or not.
So, I go back to diagnosis...jump the relay on your truck and see if it starts more easily. My guess it is the relay that is bad, because as you said, you changed the glow plugs already.
Old Jul 14, 2007 | 07:57 PM
firemediceric's Avatar
firemediceric
Neal,
I see that you have a '99 as I do. I have heard that the glow plugs will only energize if the engine is below a certain temperature. 60 degrees? Is this true?
On my Mercedes, the dome light dims as the glow plugs activate. Once the plugs turn off the light brightens and I then start the car, even though the "wait to start" light may have turned off 30 seconds earlier.
My truck starts fine as glow plugs are seldom needed in Florida, and the "wait to start" dummy light works as it should, but I don't see the dome light dim as it does in the Mercedes. My thought is to check the relay, but will the relay be engaging at these warm temps?
It's not really a concern other than I want the cylinders as warm as possible when my veg fuel is initially sprayed in.
bigmacmonday
16
Aug 21, 2013 06:34 AM
hardwaterfreak
Oct 5, 2012 09:21 AM
mabc926
Aug 28, 2010 12:51 AM
sturoe
25
Mar 21, 2007 09:37 PM
FordPowerStroke
May 4, 2005 12:27 PM
