Hello everyone. Another noob here in need of some help lol.
I recently purchased a 1973 F100 with a 360 FE and C6 tranny. The trucks is in good condition with 83,000 original miles. However, recently I drove it to work one night and just as I was about to get there the dash lights went out and the headlights starting blinking on and off. When I dimmed my lights everything came back on and stayed on for the last 1/2 mile to work. So at first I thought my dimmer was going bad but then later that night I talked to a friend of mine at work who owned a 1970 F100 for many years and he mentioned his did the same thing once and it turned out his headlamp switch was going bad. It would get hot after driving for a bit of distance and lose contact and thus the headlamps would blink on and off. So I was going to replace mine as a starting point since it does the same thing but I can't get the ***** off the switches (wipers and headlights). They just pull off don't they? I can't budge either without breaking something and I can't get the dash plate off with the ***** on. Is there a trick to it or am I just a moron and can't figure it out? Do you guys think it's the switch and not something else?
If it's the switch I found one on Autozones site for online sales only but it has no shaft or **** in the picture. Do the shafts come out of these switches? I can't post a link to the Autzone **** because your site says I have to modify my Mozilla web browser to use the function.
Welcome to FTE
The headlamp switch **** and shaft comes off as a unit. Remove battery cable for safety. Pull out headlamp **** all the way. On the bottom of the switch is a spring loaded button. Press it in, pull **** and shaft out of the switch.
The wiper switch has a spring clip holding it to the shaft. Turn the **** till you see a cutout. Inside you will see a metal insert. Use a paperclip, or similar, press the metal piece back (or forward, forget). **** comes off shaft.
You then have to remove the nuts that hold these switches to the dashboard.
Just to clarify the headlight shaft removal, you need to reach up under the dash and feel for the switch itself, and above it will be the release button that you push down on while pulling the shaft out. It should be near the back of the switch housing.]
My '77 Cougar did the same thing, and I changed out the switch and the problem went away. It came back a couple years later on the aftermarket switch, so a new Ford replacement will likely be better, if you can find one nowadays. (the car wasn't quite 10 years old when it happened to me)
My money is on you have a bad dimmer switch. I had exactly the same thing in my 67 Fairlane. The key is that when you dim the lights everything is OK. Try the dimmer switch first. They are pretty cheap and easy to install. A couple screws and unplug a couple of wires.
Thanks for all the good information and the welcome. I think I will buy both a new dimmer and the headlamp switch and replace the dimmer first, since it's easier, and the switch only if it the dimmer doesn't cure the problem. Niether are very expensive and it sounds like the headlamp switches go bad eventually anyhow.
on these trucks, all of the current goes through the switch cause the truck doesn't have a relay system for the headlights. so when you have the headlights on bright all of the current that you are using is through the switch causing it to overheat. the best way to fix the problem is to install a relay system for the headlights, that way you won't have to go back in a few years and fix it again. also so your truck doesn't catch on fire from the switch overheating and burning everything to the ground. many trucks have met there doom from that switch. I will look for the article on the website about this and post it
C0TZ-13A024-A .. Dimmer Switch (Motorcraft SW-263) ~ Fits all Ford car & trucks ~ 1960 thru the 1990's
Several years ago same thing happened to my 67 F25 late at night on a narrow road north off I80. The headlight switch was culpurt, since the relay is built into that switch, had to replace the unit, problem solved. It is easy to change, but do disconnect the battery first, a direct short around that switch will 1- scare you and require changing of clothes, and will melt under dash wires, possible start a flaming confligration.
