71 250 front disc's binding.
Old Jul 14, 2007 | 01:51 AM
Bookman's Avatar
Bookman
I've posted on my problem ealier but things have progressed and am in need of good advice. One piece at a time I've changed the or had changed the M/C , rear shoes , Proportioning valve , the other valve on the front cross member , the soft lines , and supposedly reloaded front calipers. The problem is the fronts are still dragging only half as bad as in the begining. That which made the most effect was the valve on the front cross member. At this point I feel I've changed everything and still not fixed. The guy at the shop and I talked about it and the feeling is the calipers might not be for that application. I'm totally frustrated. Any help would be greatly appreciated.
