Tach problems
Old Jul 13, 2007 | 09:29 PM
BIG R's Avatar
BIG R
Tach problems
My factory tach will work sometimes,and other times it wont do anything. Is this something common on these trucks, or is mine fixing to go out? also is there some kind of easy fix? Any help would be great. THANKS
Old Jul 13, 2007 | 10:02 PM
brownieboy525's Avatar
brownieboy525
you most likley need to replace the tac sensor it is the big nut with the two wires coming out of it on the timing gear cover right were the oil filler neck is. i am not sure how much it cost i have never replace one.
Old Jul 13, 2007 | 10:46 PM
CheaperJeeper's Avatar
CheaperJeeper
Yeah the one in my DD has been doing pretty much the same thing.
Anybody got a part number or even a description of what Ford calls the sensor?
I've tried NapaOnline, PartsAmerica, Autozone and LMC and can't seem to find one.
PLEASE don't tell me it is a StealerShip only part (with a ridiculously inflated price)....
Old Jul 13, 2007 | 10:56 PM
KJLYPW's Avatar
KJLYPW
Ford p/n E5TZ-17B384A www.intellidog.com/dieselmann/idiparts.htm
Old Jul 13, 2007 | 11:05 PM
CheaperJeeper
Originally Posted by KJLYPW
Well, that's a start....
Old Jul 14, 2007 | 12:10 AM
BIG R's Avatar
BIG R
Thanks for the info, I wonder if their as easy to change out as it seems? Also hope its not to costly like every thing else at the dealer.
Old Jul 14, 2007 | 12:32 AM
CheaperJeeper
It is VERY easy to change. Unplug the electrical connector first and then I can't remember if it takes a 7/8" or 15/16" open end wrench to start unscrewing it. Once you loosen it up it just threads out by hand.....
Old Jul 14, 2007 | 07:18 AM
brownieboy525
i looked last night for about a half hour and could not find the sensor on any parts houses web site ?? so it looks like it is a dealership part
Old Jul 14, 2007 | 01:34 PM
CheaperJeeper
...which means a stealership PRICE
Old Jul 14, 2007 | 07:59 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I paid about 50 dollars for the last one I bought.
1" wrench to fit the nut.
Old Jul 14, 2007 | 08:47 PM
BIG R's Avatar
BIG R
I can handle 50 dollars, I just hope it works. I have had a run of bad luck with it lately. THANKS
