need HP estimate for 400
Old Jul 10, 2008 | 11:58 PM
taylor78's Avatar
taylor78
400 dyno #s
I had my 78 f 250 4x4 on the dyno and got 218 hp and 300ft/lbs of torque at the rear wheels.i have 33 tires c6 and 4 10s.
What do you think the motor on its own is pushing for power and torque
Thanks
Old Jul 11, 2008 | 01:51 AM
TheBlueMule's Avatar
TheBlueMule
How do you use this HP calculator?
Is there a way I could put my numbers in to get the HP and TQ estimates of my truck? I just started my newly rebuilt 408 built with a Tim Meyer rebuild kit for the first time yesterday!!!!!!! It sounds like Bigfoot is sitting in my garage, but I do only have headers on it right now.
TheBlueMule
Old Jul 11, 2008 | 01:22 PM
hollenjoe's Avatar
hollenjoe
describe your built..
Old Jul 11, 2008 | 08:17 PM
TheBlueMule
400 ford bored .030 over
Tim Meyer high cr pistons
straight up double roller chain
new intake and exhaust valves
heads resurfaced
281 hydrolic roller cam
hyd. roller lifters and hyd. roller rockers & new pushrods
new locks, springs, retainers (built specialy for hyd roller cams)
high volume oil pump
edelbrock performer 400 intake
670 cfm holley truck avenger carb
headers
I think thats about it. Will that work for ya to get me some numbers?
Thanks guys
TheBlueMule
Old Jul 11, 2008 | 08:45 PM
hollenjoe's Avatar
hollenjoe
is that a custom hydraulic cam? can you give me the numbers for it
Old Jul 12, 2008 | 01:03 AM
TheBlueMule
No it is not a custom grind cam. It is just a hyd roller comp cam. Would you be able to go to the Comp Cams website and type in 281HR as a grind number under the search box? Once that comes up, you can click on Cam Specs and it will show you all kinds of info on the cam. I couldn't find just easy simple straight forward numbers. I am somewhat new to these old gassers and Im not sure in what order the numbers go. I really really appreciate it.
Thankyou very very much
TheBlueMule
Old Jul 12, 2008 | 01:14 PM
hollenjoe's Avatar
hollenjoe
ok , so what fuel octane will you be using? Is the engine completly assembled? your dcr with that cam and 9.5:1 will be 7.56:1 which is good for 89 octane, i would personaly mile my heads to a total of 0.025" to get around 10:1 and boost my dcr to 7.9:1 which will be good for 91 octane and will get you better torque, my opinion, anyways heres the math asuming you have an open exhaust:
torque
414@2000
444@3500
hp:
378@5000
Old Jul 14, 2008 | 12:40 AM
TheBlueMule
yes the engine is completely assembled and I will probably be using 89 octane. I was going to have my heads milled but I was told not to by a few people on this site because it would be too much with the higher cr pistons from tim meyer. How much more power do you think you are talking about with milled heads and 91 octane?
thank you very much hollenjoe. I really appreciate it.
since you know quite a bit on these engines, what do you suggest for a break in on the motor? everything is new except for the crank rods and block. lol
thanks
TheBlueMule
Old Jul 15, 2008 | 11:07 AM
hollenjoe's Avatar
hollenjoe
well that has been a discusion around here, the most delicate part you will should be worring about in the break in procedure are your piston rings and bearings since you have a roller cam and the break in procedure should be less delicate than iwith a flat tappet, anyways what ive always done is simply to change the oil a week after the engine first ran. Pros around here recomend using an oil with zddp aditive and 20w40 , whcich is only available with in some diesel oils, I found one in a napa store and bought 2 galons, dont really remember the brand, ive also heard Tim`s is selling an oil with this aditive....
your camshaft shouldve brought breaking in instruccions, for a hyd flat tapped i ran the engine for 20 min on 2000-2200 rpm then went to 2500 for about 5 mins, rollers should be fine using this procedure also, but read your instuctions... more opinions-advices?
ragens 87
Jul 4, 2016 05:56 AM
good to doo
Aug 18, 2014 06:46 AM
67f10067
Jan 9, 2011 11:18 PM
compressorguy
Jun 24, 2008 11:44 AM
jokerforever
1978 - 1996 Big Bronco
Jul 10, 2007 03:33 PM
