Check Engine light
Old Jul 13, 2007 | 04:58 PM
sjrogers's Avatar
sjrogers
Check Engine light
I have a '02 Ranger 4x4 with 4.0 v6, Auto trans 106k miles. The check engine light just came on. I went to Autozone for a code read. Its the Egr flow. I took the EGR off and sprayed some carb clean in it, then bolted it back on, I did check it with a vacuum to make sure it does work. The check engine light is still on. Any ideas before I take it to the repair shop. Will the check engine light automatically reset?
Steve
Old Jul 13, 2007 | 11:08 PM
pawpaw's Avatar
pawpaw
Check the DPFE sensor, as it's a common problem EGR system part & it provides feedback to the computer that affects the EGR valves flow.
There is a link in the "Tech Info" thread, located atop this foums thread listing page, that has some good info on how to test your EGR system.
Let us know how it goes.
