Sponsored by: Real Truck
brake pulling...vibration when braking
Old Jul 13, 2007 | 11:12 AM
mhanley's Avatar
mhanley
Question brake pulling...vibration when braking
Hi All....Please HELP!
My truck is a 2002 F-350 xl 7.3 L diesel, single rear wheels. I have a vibration when braking. My truck has 61K on it. I've changed the brakes, calipers and rotors on the fronts, (rotors and pads needed it, thought the caliper was sticking.) but the truck still pulls. My tires aren't the best. I've checked the front suspension and the tie-rod bushing was pretty worn. I could move the tie-rod assembly and tie rod end with my hand while the truck was on the ground. I know that the tie-rod ends have rounded "*****" so to speak, but should I be able to move the entire assembly within its range with my hand? Could that be causing my problem. The truck only vibrates and pulls (to the right) when braking, and at all speeds.
Thanks in advance!!!!
Mark
Old Jul 13, 2007 | 03:02 PM
redford's Avatar
redford
FTE Leadership Emeritus
If it vibrates and pulls to the right while braking, you still have a brake problem. You need to get it fixed ASAP!
You have one rotor that is warped (vibration) and one caliper that isn't working properly (pulls to the right).
Old Jul 13, 2007 | 03:45 PM
redford's Avatar
redford
Did you lubricate the caliper slide pins?
CourierYVR
Aerostar
31
Aug 28, 2012 08:40 PM
MontanaMan
Oct 26, 2011 06:26 PM
Superred2
19
Jun 28, 2011 10:41 PM
eigenvector
1983 - 2012 Ranger & B-Series
May 7, 2009 08:33 AM
markjw
General Automotive Discussion
Jan 13, 2006 09:28 AM
