Stalling 302
Old Jul 13, 2007 | 11:04 AM
302 F-150's Avatar
302 F-150
Stalling 302
I finally got around to finishing the carb swap and cam install on my 89 f150 today. I started it and it ran fine but stalled after about 10-15 seconds of running. After it stalls it will start up again and do the same thing. The motor has an edelbrock performer intake, carb and cam and an hei distributor if this helps. Any help would be appreiciated.
Old Jul 13, 2007 | 11:38 AM
Kemicalburns's Avatar
Kemicalburns
are you running a mechanical fuel pump or still running off the electric pump in the tank? have you installed an adjustable fuel pressure regulator?
Old Jul 13, 2007 | 11:45 AM
302 F-150's Avatar
302 F-150
It is running off the electric pump and I am using a mallory return style regulator
Old Jul 13, 2007 | 12:20 PM
Kemicalburns
what psi do you have the regulator set to?
Old Jul 15, 2007 | 07:52 AM
LxMan1's Avatar
LxMan1
Is it losing spark or is it a fuel problem?
Old Jul 16, 2007 | 11:19 AM
302 F-150's Avatar
302 F-150
I have the regulator cranked all the way up and I can only get 6-7 psi out of it. It will run, but after about 20 seconds the fuel pressure will drop to close to zero and it will stall. I dont have much fuel in the tank, could this have something to do with it?
Old Jul 16, 2007 | 03:50 PM
HemiEater's Avatar
HemiEater
needs fuel to run....hello...
replace the filter
pull the line off the carb and turn on the pump..see how much fuel you get out of it..let it run for a while see what happens...sounds like a clogged filter to me....but who knows it could be out of gas.........
Old Jul 16, 2007 | 05:30 PM
302 F-150's Avatar
302 F-150
I replaced the filter and filled up the tank and still no go. I pulled the line off the carb and right when you turn the key, a fair amount of fuel comes out but just for about half a second.
Old Jul 16, 2007 | 05:47 PM
HemiEater's Avatar
HemiEater
What is turning on the fuel pump?
Does the pump run all the time or just for a few seconds after you turn the key?
Old Jul 16, 2007 | 06:04 PM
302 F-150's Avatar
302 F-150
I have a switch to turn on the fuel pump and the pump only runs for a few seconds when I turn the key and flip the switch.
Old Jul 16, 2007 | 06:26 PM
HemiEater's Avatar
HemiEater
So it runs all the time after you flip the switch?
Old Jul 16, 2007 | 06:31 PM
HemiEater's Avatar
HemiEater
sounds like the pump needs a direct connection............or feed the fuel pump relay some power off the ignition, so when the key is on the relay is on feeding the pump power all the time....by-pass the computer that keeps turning it off.
Old Jul 16, 2007 | 06:56 PM
302 F-150's Avatar
302 F-150
So just unhook the two wires on the fuel pump and wire it as I would wire an aftermarket electric fuel pump with a switch and that should do it?
Old Jul 16, 2007 | 07:39 PM
HemiEater's Avatar
HemiEater
I guess.....but you are better off using the relay thats all ready there....just feed that power or a ground which ever the PCM uses to turn on the pump.....
Old Jul 16, 2007 | 07:41 PM
HemiEater's Avatar
HemiEater
it's easyer than it sounds......
