fuel pump
Old Jul 12, 2007 | 09:01 PM
patjr_45's Avatar
patjr_45
fuel pump
hey i was wonderin if any of yall know where my fuel pump would be located on my 4.9L inline 6 1994 ford f-150 xl. i have a 13 gallon tank if that helps. and if u know the easiest way to replace it let me know please. ok thanks
-Pat
Old Jul 12, 2007 | 09:27 PM
Bandit-1's Avatar
Bandit-1
i belive it is the fueltank.
Old Jul 12, 2007 | 09:38 PM
patjr_45's Avatar
patjr_45
thanks yea i was thinkin the same thing since i couldn't find it anywhere else. you have any ideas on removing the old one?
Old Jul 12, 2007 | 09:47 PM
msb71's Avatar
msb71
First ya have to disconnect the fuel lines , then drop the tank , should be easy to get out from there.Make sure you either drain the fuel or run it til it is almost empty ,those tanks can get heavy.
Mike
Old Jul 12, 2007 | 09:50 PM
ryan f150 4x4's Avatar
ryan f150 4x4
why do you need a new pump?dose the truck run at all .You might just need a new relay. If you need a new pump take the bed off or drop the gastank remove the sender and pump. not a hard job just a pain in the a$$
