airbag code 27???
https://www.ford-trucks.com/forums/6...code-27-a.html
And, I still have the dash light and the code flashing. I can use a jumper on the board when it is out of the truck and the new bulb lights up so I know it works and is in correctly.
In looking at how the 'on-off' switch works I can't see that it even touches the circuit board, and if it does it doesn't do anything that I can see. There is a small white plastic 'dodad' with a small metal dowel in it that moves with the key, away from the board when in the 'On' position and toward the boaed on the 'Off' position. There is nothing on the board, that I can see, for the plastic 'dodad' to contact when in the 'Off' position.
I know that everything I typed above sounds rather vague and confusing but I don't know any other way to explain it. If you have taken one of the airbag boxes apart then you will know what I'm trying to say.
If anyone has done this 'fix' maybe they can tell me what I'm missing here.
Thanks,
Hal
