blower/NOS question
Old Mar 14, 2002 | 02:28 PM
buttnuttn8's Avatar
buttnuttn8
blower/NOS question
Yeah i got a good question for ya.... I was thinking about slappin on a blower or nos on my truck to compeet in mud boggin. Some friends of mine said that if you want to do that you want lower compression ratio. The motor i had built the motor man told me i have 12:1 compression is this to high to use a blower? will it come all undone or would i be alright?
any info would be loved thanks
Old Mar 14, 2002 | 08:36 PM
proeliator's Avatar
proeliator
blower/NOS question
That is really high for a blower. Blowers work with lower compressions, like 8:5:1. NOS doesn't "need" lower compresion, but you do stand a much higher chance of blowing you block through your hood at your compression. I ran NOS with 10:5:1 with nary a problem for a year and the block wasn't even built for it. To be honest, if you wanted to save your engine it would need to be built to maximize/handle either set-up. If you do go with NOS don't go with too big of a shot, a 100# cheater should do it. Unless you set up your engine for it of course. Good luck and have fun.
Old Mar 18, 2002 | 02:35 PM
project56's Avatar
project56
blower/NOS question
I have a 2 stage kit on my dragster. I am running 10.5/1 comp. That engine held a 500 shot. It was built for it though. It still runs great. That car is gone this weekend though.
1956 F100
460, C6, 9 in. rearend
91 GT
Stock, except flomasters
99 Chevy 1500 Z71
Old Mar 18, 2002 | 10:25 PM
mustange70's Avatar
mustange70
blower/NOS question
Remember that NOS (i think) is for flat peddle to floor all the time, and that a 10ld of nitrous will last on average just a little over a minute.(Nitrous takes bout 5lbs a minute (on 100hp shot) and 5lbs left in the bottle is not enough pressure to run it)
82' Flareside with 400 horse under the hood
Old Mar 19, 2002 | 11:34 PM
lshort's Avatar
lshort
blower/NOS question
Ran a 71 ford mud dragster with a 351c and 12to 1 pistons with 175
horse of nitrous boost for sevral years in the mid 80s basicly I would
win or break.It was very hard on ring and pinion and axels.But the engine took it well,burnt the electrodes off a few plugs and blew a couple head gaskets.
it is great stuff though what a kick in the pants I highly recomend it,get a good fuel pump and forged pistons and go.
Larry
Old Mar 20, 2002 | 11:34 PM
jetboat429's Avatar
jetboat429
blower/NOS question
Have heard that the crank snout is a weak area for a blower.As for the nos it should fine if you stick to a low hp unit (depends on your motor set up)Right now i added a 100hp super power shot to my boat and it works great.motor has a stock lower end and pistons too.(reason im only at 100hp)the bottle does go fast though.
Old Mar 21, 2002 | 07:34 AM
shazam's Avatar
shazam
blower/NOS question
