compression ratio
Old Mar 19, 2002 | 10:40 PM
PigFarmer's Avatar
PigFarmer
compression ratio
Can I expect pinging On my 1989 302 with compression ratio at 9.55/1 ?
Thanks
Randy
Old Mar 25, 2002 | 10:54 PM
TorqueKing's Avatar
TorqueKing
compression ratio
It depends on the fuel you are using, and the cam you have. If you have the stock cam, you can expect cylindar pressures around 180 psi. The static compression ratio doesn't dictate the detonation/fuel requirements as much as the dynamic compression, or cylindar pressure. Above 180 psi, you should run premium (93 octane), and your timing advance should not exceed 36-38 BTDC. below that, you can get away with midgrade fuel/or even the cheap stuff, so long as your timing does not exceed 36 deg. BTDC, again, depending on cylidar pressure.
Happy Wrenching,
John F. Daly III
The TorqueKing
Old Mar 25, 2002 | 10:58 PM
TorqueKing's Avatar
TorqueKing
compression ratio
IsoGrifo
Oct 16, 2009 06:37 PM
randy-schendel
New Member Introductions
Jul 24, 2006 06:10 AM
chulsey12
Nov 13, 2002 10:08 PM
FTE Ken
Site Announcements
Nov 6, 2002 04:59 PM
fordtruckin
Apr 13, 2002 10:12 AM
