Putting cam straight up
Old Jul 11, 2007 | 09:54 PM
79f100six's Avatar
79f100six
Im going to be putting a 400 into my truck and was wondering about putting the cam straight up. Do i need to change the timing gears that have the marks or what. If so what brand has the marks and i wanted to do this on the cheap. I am also planning on changing the chain anyways since the miles are unknown anyways.
Old Jul 12, 2007 | 06:15 AM
danlee's Avatar
danlee
My local auto store sells an Edelbrock # 7821 for about $61.00. That is a double roller set with three keyways. I am sure that it is worth the extra money over a cheap OEM replacement.
Old Jul 12, 2007 | 11:39 AM
grclark351's Avatar
grclark351
stock cam that is in a used engine or aftermarket cam?
Old Jul 12, 2007 | 11:53 AM
79f100six's Avatar
79f100six
Not sure, the motor is still in the other truck. But i am guessing stock, the truck has a edelbrock 600 cfm carb, intake, longtube headers, chrome velve covers but i dont know if the motor has ever been taken out of the truck. But i was wondering is it really worth it putting the cam straight up. Is there that much power improvement since money is tight and was wondering the time and $60 getting new gears or would it be possible to do it with stock gears.
Old Jul 12, 2007 | 01:45 PM
danlee's Avatar
danlee
A replacement timing set will cost about $21.00. You have to do all the same work for either set, so you are only saving $40.00. You will gain some power at low RPM, there is no debate in my mind. But you have to do what you have to do.
