Debugging PO wiring hack-job
Old Jul 11, 2007 | 04:42 PM
czaroc's Avatar
czaroc
Well I've been spending my day off fixing/tearing out all the wiring that the PO hosed up.
76 F250 390 Manual-4spd SuperCab.
It used to have a dual battery setup. half of the parts including the battery were removed before I purchased. Now I have a few wires I'm trying to reroute.
There is a set (1 blk w/ 20GA fuseable link, 1 red w/ 16GA fusable link) that have a common ring terminal. Looks like it used to run to the secondary battery, but could go to the main. THIS IS A STOCK WIRE. it runs through the firewall... connects to a square flasher unit thingy and back out the firewall into a large wiring loom.
What is it? why did the truck run fine without it? I think it should be attached to the main battery... not sure.
Old Jul 11, 2007 | 05:44 PM
rusty7983's Avatar
rusty7983
my truck was the work of the hacked wiring po. it sucks. the wiring in the cab, does it have an isolater switch? turn one battery on and one off? maybe it was used on a camper?
