Sponsored by: Real Truck
Upper console not working
Old Jul 11, 2007 | 01:08 AM
greg222's Avatar
greg222
Question Upper console not working
Good morning !!
I have a 2000, V-10, F350 SD Lariat
The upper console is completely out, the fuses are good.
Is there any updates or repairs to this ??? Maybe a module of relay ??
Thanks !!
Greg
Old Jul 11, 2007 | 02:57 AM
Drumaniac3000's Avatar
Drumaniac3000
I'm having the same problem and was wondering the same thing....
Jason
Old Jul 11, 2007 | 05:57 AM
rgonot's Avatar
rgonot
I had this problem for a few weeks. Checked fuses and everything. Turns out my dimmer switch was turned so low the overhead turns off. I run with my headlights on all the time. Hope that is your problem but if not...I sure felt dumb when I realized it
Old Jul 11, 2007 | 08:41 AM
msgtg's Avatar
msgtg
If the dimmer switch isn't the problem, do a search. I remember reading a post (it's been over a month ago) where someone found a chaffed wire that caused the problem.
Old Jul 11, 2007 | 10:24 AM
Beerstalker's Avatar
Beerstalker
There is a well documented problem of chips coming loose in the computer and causing it not to work. Do a search for "overhead" or "trip computer", and you should find a few different threads on it with directions on how to fix it. If not post in here again and I will try to find it.
