Good morning !!
I have a 2000 F350 4x4, V-10
The upper console for the Temp, mileage ect data does not work. I checked all the fuses inside the cab and inder the hood, all OK
The display is blank.
Is there a relay or module I can check ?? If so, where is it located ??
Looks like you have some replies in the Super Duty forum. Use the site as much as you want and be sure and stop in your state chapter. I have the link right here: https://www.ford-trucks.com/forums/forum183/
