Porting Smog Heads?
Old Mar 25, 2002 | 09:19 AM
KSisk's Avatar
KSisk
Porting Smog Heads?
[updated:LAST EDITED ON 25-Mar-02 AT 10:43 AM (EST)]I have a set of smog heads on my 82 302. I'm in the process of porting and polishing. I'm planning to grind the A.I.R. orifices, in the exhaust ports, flat and plug them up. My question is, what is the easiest and cheapest way to plug the orifices? i.e. welding, brazing, JB Weld ...etc
Thanks in advance!
Chevy Trucks, like a rock!
Yea, like a flat rock!
easy to break and won't roll.
Dodge Trucks, the rules have changed so they could win!
Old Mar 25, 2002 | 11:32 AM
rusty9's Avatar
rusty9
Porting Smog Heads?
>Thanks in advance!
I have heard that working with the cast manifolds is difficult and results can be disappointing. maybe try just capping-off the inlet tubes from the outside. Or do you need a smooth surface on the inside runner? Have you thought about headers? they shouldn't be too expensive for the 302. probably work well with your porting job.
good luck,
Rusty
Old Mar 25, 2002 | 08:57 PM
KSisk's Avatar
KSisk
Porting Smog Heads?
I've already plugged the external tube ports. I just need something to fill in the cavity left after grinding down the AIR bosses in the exhaust runner. I wonder if that hi temp muffler mud would work...lol
I'll probably have to tap the hole and plug it with a bolt or stud; but, that wiould be a pauin to grind down...There's got to be an easier way.
Old Mar 28, 2002 | 08:44 PM
redranger1's Avatar
redranger1
Porting Smog Heads?
jb weld would be ok, but i dont know how it will hold up to the heat? try this company
www.cotronics.com
they have some special epoxies that stand up to hi temps. hope that helps some.
-nathan
Old Mar 28, 2002 | 11:01 PM
KSisk's Avatar
KSisk
Porting Smog Heads?
[updated:LAST EDITED ON 29-Mar-02 AT 00:03 AM (EST)]Thanks for the great tip NATHAN!
I ckecked out Cotronics, they have exactly what I'm looking for, gonna give em a ring tomorrow! They have some other products I can put to good use on other applications, as well.
Hey, thanks again, Nathan
Old Apr 2, 2002 | 10:44 AM
Brian's Avatar
Brian
Porting Smog Heads?
The thermal cycles usually destroy glues over time. I am at the same point as you and was going to press fit some pins into the holes. I'm debating brass, aluminum or stainless. All of these materials have a greater coefficient of expansion so as the head heats up they get tighter. The brass would be the easiest to finish flush.
Old Apr 3, 2002 | 06:09 PM
KSisk's Avatar
KSisk
Porting Smog Heads?
I got some stuff at Autozone called Thermosteel...made for repairs to exhaust manifolds and head...supposed to withstand 2400 degrees F. and gets stronger with heat. Ever heard of it?
Thanks,
Ken
Old Apr 11, 2002 | 11:22 AM
Chuck 6083's Avatar
Chuck 6083
From: Where they take the census by counting the appliances on the front porch and multiplying by five
Porting Smog Heads?
Hey guys,
I talked to a long-time Ford man and drag racer and he says "just plug the hole on the outside, and grind the orifice down to even with the roof." He says not to worry about plugging the hole in the ports. Plug it on the outside and don't worry about it in the ports. He's done it both ways and says there's nothing to be gained.That's the route I'm going anyway!
Chuck
Old Apr 17, 2002 | 07:15 AM
airharley's Avatar
airharley
Porting Smog Heads?
Old Apr 19, 2002 | 12:55 PM
Art's Avatar
Art
Porting Smog Heads?
Chuck is right. That's exactly what I did on the 1982 302 that's in my 1969F100 2WD - that was over 35,000 miles ago without any problems!
Art
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3467&.jpg
E1234
Jul 12, 2015 01:04 AM
eyyu
19
Jun 12, 2015 05:38 PM
LIQUID8
Apr 22, 2015 01:46 AM
Soarer
15
Apr 24, 2014 10:49 AM
chpierce
Feb 24, 2014 02:58 AM
