where is the maf sensor located and is it hard to change, After changing is there anything that needs to be done to have it work correctly. Sorry if this question seems silly but I need to know
On my previous '02, it was between the TB rubber snorkel and the filter airbox; on my '04 the mount is built into the airbox outlet. If you do a stock replacement, the EMC will pick it up with no problem; just be careful, they're delicate.
the maf is mounted between the airbox and rubber intake tube... you should unhook the battery for 10 minutes to clear the keep alive memory (KAM).. because the maf also acts as a barometric pressure sensor and that will force it to resample the pressure to get the air/ fuel mixture right
