Shifting problem
Old Jul 10, 2007 | 05:50 PM
89Firebird2.8's Avatar
89Firebird2.8
Shifting problem
Greetings, I have a 1992 F-350 CC/LB with a 351W and 5-speed manual tranny. It's at 150K and it's been having issues shifting. Sometimes i can't push it into 1st or reverse, and i have to shut it off to get the shifter into position. This only happens occasionally, not all the time. It also likes to grind a lot shifting into second, usually on downshifts. Also, the clutch pedal won't come up on its own, you have to pull it up with your foot, which makes driving really inconvenient, but this is a work truck, so I need it running right. Any ideas what this problem is, how hard it is to fix, and how much it will cost? Also, i assume that it is a zf-5 that comes in this truck. Or does the zf-5 just come in the 460 and the 7.3 while the 5.8 gets a different trans?
