Sponsored by: Auxito
quick question
Old Jul 10, 2007 | 05:29 PM
alberta46's Avatar
alberta46
quick question
I am changing out my rear end on my 97 f150. I have found a entire rear end which matches the bolt pattern for my wheels its out of a 98. my question is if it is a 9.25 will it fit even though I have a 8.8? now I am talking the complete rear here axles and all I am taking out the whole piece and replacing it
Old Jul 10, 2007 | 07:35 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
It should bolt right onto the leaf springs. The only thing you might have a problem with is the driveshaft. I think the differential is a little longer than that of the 8.8 (the pinion length), so you might need a shorter DS (or find a truck with the same wheelbase and drivetrain as yours that origionally had the 9.75 and take that DS and use it)
Old Jul 12, 2007 | 06:10 AM
alberta46's Avatar
alberta46
Thank you atc. When I picked up the diffs I got the d/s too so I should be good.
