Main Bearings
Old Apr 25, 2002 | 05:17 PM
td351w's Avatar
td351w
Main Bearings
How can you tell if main bearings are worn? Thanks
Old Apr 25, 2002 | 06:31 PM
Ratsmoker's Avatar
Ratsmoker
Main Bearings
The method I use to tell if an engine has worn main/rod bearings is to rev it up to about 2500rpm and listen for a deep knocking sound coming from the bottom end. Main bearings and rod bearings make about the same sound and if your mains are worn more than likely your rod bearings are too and vice versa. There is a way to distinguish which bearing is making the noise when you rev it and let off but I don't remeber or do I care. If you replace the mains you are gonna replace the rods anyway.
Old Apr 25, 2002 | 07:50 PM
Franklin2's Avatar
Franklin2
Main Bearings
Low oil pressure + a very low frequency thumping noise and sometimes a leaky rear main seal to go along with it.
Old Apr 26, 2002 | 11:28 PM
metalboy's Avatar
metalboy
Main Bearings
