E40D Problem
Old Jul 10, 2007 | 11:33 AM
JQ's Avatar
JQ
E40D Problem
I've owned my '92 F250HD 4x4 7.5L since new. The truck is stock except for a Banks intake and exhaust system.
From the beginning I've had a problem with the converter. When traveling slowly off-road (even on moderate grades) for a period of time; or when backing with a trailer up a grade, the converter overheats and spews trans fluid from inside the bell housing (not the top vent). I lose about a 1.5 quarts. After it cools, there is no leakeage of fluid. The trans temp stays normal (the guage is reading at the pressure test on the trans housing so it doesn't see the converter temp). There are no other signs of incorrect operation.
I had Banks install a Trans Command module (problem existed prior to install). I went to an oversized cooler and conducted a flow check that showed normal. Ford replaced the trans and converter in 1998 with the then latest E40D mods and it made no difference.
I've been to many trans shops and to Ford with the problem. Each time I've drawn a blank. Has anyone else had this problem? Any suggestions?
logcruiser
16
Jul 13, 2013 10:36 PM
SpectreZ91
Apr 12, 2012 08:10 AM
Schmavic
17
Jul 10, 2010 06:32 AM
JQ
Offroad & 4x4
Jul 11, 2007 06:36 PM
Schmavic
Offroad & 4x4
22
Jun 5, 2004 11:52 PM
