Sponsored by: Auxito
Need help testing coils!!!
Old Jul 10, 2007 | 01:19 AM
Rez Ford's Avatar
Rez Ford
How do I test the coils using an ohm meter tester? There all out but i'm not sure which resistance to set the meter at?
Old Jul 10, 2007 | 05:03 AM
Half Breed's Avatar
Half Breed
First of all which meter do you have? 2nd you should only have only ohms setting. What is you actual problem? Which engine ? COP's or 4-tower coil packs? Don't know about the COP's but on the 4-tower you only get resistance in the plug connection for the wireing harness. Maybe someone else will come in with more info.
Old Jul 10, 2007 | 06:28 AM
projectSHO89's Avatar
projectSHO89
Resistance checks of COPs are next to worthless most of the time.
Steve
Old Jul 12, 2007 | 06:51 PM
Rez Ford's Avatar
Rez Ford
All Fixed And Running
Thanks guys, but I got my truck up and running. The coils were fine and tested okay. the spark plugs were fine too except one which I cleaned. Now my truck runs great. I also replaced the timing chain and oil pump. Oh... I own a 2000 F-150 4X4, 5.4L truck.
Old Jul 13, 2007 | 01:07 AM
LxMan1's Avatar
LxMan1
Glad she's back on the road
