timing help on 84 I6
Old Jul 9, 2007 | 08:16 PM
the kid's Avatar
the kid
how can i set the timing on my 84 300 6. and what do i set it at
Old Jul 9, 2007 | 08:27 PM
Franklin2's Avatar
Franklin2
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Look on the sticker on the radiator support or somewhere on the engine for the setting.
Old Jul 10, 2007 | 08:51 AM
mctrick's Avatar
mctrick
timing
it's 10 degree btdc, Take some sand paper and go around the bottom pull if it's rusted or clean it with some carb cleaner if it's got alot of grease all over it. Then find the timing mark and use soap stone to mark the notch in the pull to see it with the timing light.
Old Jul 10, 2007 | 09:12 AM
Harfend's Avatar
Harfend
I have had some difficulty finding a "timing mark" on the pully. I have found a rather large "notch" but no raised line as I have found on other engines. I have been told this notch is for a crank position sensor and these pulleys dont provide a timing mark. I ended up setting the timing by ear. Dont forget to disconect the SPOUT wire before setting the timing if you have a TFI ignition.
Good luck!
Old Jul 13, 2007 | 04:44 PM
fordlovingwelder's Avatar
fordlovingwelder
time off of the intake side though and not the timeing cover other wise you will run like crud
Old Jul 13, 2007 | 10:24 PM
Butl85's Avatar
Butl85
300 sixes must be the hardest motors to time. I asked the same question a while back and seems like nobody knows 100% how to time them. ha. I guess I need to go take a picture and post it here to people can tell me exactly what to line it up with and do. I've had some people tell me to unhook my vacuum advance. That would be cool but my truck doesnt have one.
Old Jul 14, 2007 | 11:44 PM
Kalashtar's Avatar
Kalashtar
Sand the balancer find the FINE ENGRAVED LINE, not the big notch. Match that up with the timing tab on the passenger side of the engine. I'm 100% sure of it.
