Compression psi/ratio
Old Jul 9, 2007 | 06:31 PM
matt16875's Avatar
matt16875
I'm going to be doing a compression check on my 351w +.040 here shortly. What would be the PSI of a 9:1 compression ratio motor?
Old Jul 9, 2007 | 07:08 PM
HemiEater's Avatar
HemiEater
it's hard to say...the cam will effect the pressure...what you want is a good even number on all 8... if you get one thats way out say 50psi low then you have a problem....just keep track and do them all,
Make sure you open the throttle all the way and remove the power from the coil....make sure you spin it enough, I like to hit the guage 5 times.
Old Jul 9, 2007 | 10:56 PM
matt16875's Avatar
matt16875
Gotcha Hemi. Do you think that Cam Research would be able to tell me the pressure since they built my cam? I didn't realize ya had to hold the throttle wide open. Good info as always.
Thanks Hemi!
Old Jul 9, 2007 | 11:37 PM
kc5gxl's Avatar
kc5gxl
You should also remove ALL the spark plugs when doing a compression test. As long as the compression is relatively even, Ford says something like within 20# of each other, then the compression is good. I would think that a good comp reading would be somewhere around 120 PSI or more.
Hope that helps some,
Dan Harriman 84 F150 lwb
Orange, Texas
Old Jul 10, 2007 | 04:44 PM
matt16875's Avatar
matt16875
Cool, thanks Dan.
1975-F6004x4Dump
19
Feb 9, 2014 09:43 PM
cervantes
Oct 19, 2009 04:55 PM
IsoGrifo
Oct 16, 2009 06:37 PM
MontanaFord
13
Jun 27, 2004 01:18 PM
FatMike86
Jul 20, 2002 06:16 PM
