Sponsored by: Auxito
EGR Valve
Old Jul 8, 2007 | 07:55 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
EGR Valve
I need to know if the throttle body on the 5.4l and the 4.6l are the same and the egr valve assembly behind that... basically from what i can see they look exactly the same and the just moved the postion of the return for the exaust and also moved... basically it has been rearanged but uses all the same parts..
Thanks
Old Jul 9, 2007 | 01:10 AM
LxMan1's Avatar
LxMan1
Well, MACperformance shows the same 75mm TB for both engines so they may be the same. The only difference may be the blade diameter on the stockers. My 5.4L one measured 68mm with a pair of calipers. You might compare the blade sizes and if different, use the bigger one.
I'm curious to see how this thing launches with the 4.6L torque converter in it!!!!
Old Jul 9, 2007 | 06:17 AM
BURNSTOUGHFORD
Blade diameter? you mean the butterfly? The reason im wanting to swap them is to gain some clearance and also the mounting of the 4.6l idle air control and EGR are much better than they are on the 5.4l....
Old Jul 9, 2007 | 06:18 AM
BURNSTOUGHFORD
Oh and yea i bet it will leave pretty hard... at least compared to a stock 5.4l..
Old Jul 9, 2007 | 06:19 PM
BURNSTOUGHFORD
bump back to the top
Old Jul 9, 2007 | 08:09 PM
puppypower's Avatar
puppypower
I don't know what the setup feels like for a true stock 5.4 but I have the 5.4 with the 4.6 torque converter and the 4R70w tranny and it does have a pretty good take off. The wife spins the tires all the time. Lead foot. In matter of fact, thanks to my wife, I had to replace my spider gears.
Old Jul 10, 2007 | 06:09 AM
BURNSTOUGHFORD
What did you do about your exaust when you swaped in the 5.4l?
