Weird Things just started- Electrical
Old Jul 12, 2007 | 06:58 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by wagcoll
A few years ago, I had a strange problem, and you guys on here told me just what it was, ( cam position sensor) and I had it fixed immediatly. I don't know about this one, but I'm keeping my fingers crossed. I have 1999 7.3 L. Power Stroke Diesel, about a week ago, first I noticed strange things going on, like my ADS light came on, then the Overdrive was flashing Off. Then my speedometer went crazy, one day I was slowing down to stop when I got to about 30-35 mph it would just drop to 0. I've been working long hours, and had not had time to check into this. Then today, it seems that it has just decided die if I go over 40 mph. It will start back up, but will die again if I get to 40 mph. I've checked and noticed to that my trailer lights don't work either. Does anyone have any ideas where to start?
I'm with Kennedyford on this one. An ABS sensor, while it fixed the other stuff, has nothing to do with the engine stalling out.
Old Jul 12, 2007 | 07:11 AM
toproller's Avatar
toproller
The same thing was happening with my speedo and i changed the VSS, but it's still doing the same thing, once it hits 30, it drops to 0. What could be the problem.
2002 F-350 SRW
Hypertech Chip
4" Down Pipe
5" Exhaust
K&N Free-Flow Air Filter
Old Jul 12, 2007 | 05:39 PM
wagcoll's Avatar
wagcoll
Red face It didn't fix everything!!
Well I took the truck out today, and apparently all is not fixed yet. Everything is working properly as for the other problems, but now it just dies for no reason. Does not matter what speed now. I may go 10 miles or may go 2 miles, then it just dies. I can start it up ok most of the time, and it may run for a while, and it may not. Other times I have to wait a little bit. Now, I thought I would move on to the next advice, changing the VSS. Where it this located? My ABS was located on top of the pumpkin, I can't find any VSS there? Also is there any chance that the CPS is going out again? I have only replaced it once a few years back.
Old Jul 12, 2007 | 05:53 PM
God_hammy's Avatar
God_hammy
the abs and vss are the same sensor.. only 1 sensor
Old Jul 12, 2007 | 06:07 PM
dryfly's Avatar
dryfly
Not according to Napa.Go in there and ask for a vss and they will hand you something that goes on your tranny.Its got a mechanical con.(spedo cable maybe not sure) and an electrical connector (3 prong if i remember).
Old Jul 12, 2007 | 06:29 PM
wagcoll's Avatar
wagcoll
Thats what I was told. Napa has schematics, and shows that there is two sensors on the pumpkn. The only problem is my truck has just the ABS one. Thats why I ask where is the VSS located.
Old Jul 12, 2007 | 06:42 PM
dryfly's Avatar
dryfly
I didnt get into the v.s.s. I just told the clerk that was not what I was looking for.As far as where it goes I think I remember someone on here saying it goes aon the trans somewhere.I dont even know what it is supposed to control but I do know nappa has one for my truck.
Old Jul 12, 2007 | 07:07 PM
Action4478's Avatar
Action4478
2002 F-350 SRW
Hypertech Chip
4" Down Pipe
5" Exhaust
Have you checked the wiring that runs to the VSS?....
Old Jul 13, 2007 | 07:07 PM
wagcoll's Avatar
wagcoll
Well it seems I've come full circle. As I said in the first post that I had changed the CPS a few years ago as the board suggested would fix my problem. And today I had to change it again, and fixed the last of the strange set of problems that had been occuring over the last week. Thanks to everyone for their help.
Old Jul 13, 2007 | 08:19 PM
BobbyDiesel71's Avatar
BobbyDiesel71
Thanks for the help, I'll start there, and let you know.
DEF VSS, get the NAPA version or even the FOMOCO
I have always had good luck with my auto body guy, I can get you a quote if need be.
any help, feel free to IM me
bob
Old Jul 14, 2007 | 10:53 AM
God_hammy's Avatar
God_hammy
the VSS and ABS sensor ARE the same, the sensor on the trans. is called an OSS and is used for trans. functions... I am a ford tech, ive changed many of these.
Hollywood1275
Mar 23, 2013 07:49 PM
cutlass
Mar 9, 2010 01:28 PM
a.mcewan
Nov 18, 2009 08:02 AM
tshelton
Jun 4, 2007 02:20 PM
tom_foreman
Aerostar
21
May 19, 2006 08:57 PM
