Oil Pressure Sending Unit
Old Jun 24, 2002 | 11:55 AM
MonkeyBoy's Avatar
MonkeyBoy
I am trying to locate my oil pressure sending unit. I have a 1978 F150 4x4 with a 400 engine. I would appreciate any help. I am experiencing sporadic low oil pressure and would like to check the sending unit first.
Old Jun 24, 2002 | 01:59 PM
Brncomtb's Avatar
Brncomtb
I had the same problem in my '94 and it turned from sporadic to pretty much constant low pressure really quick so be careful. My pump had gone dead after 117,000 miles.
Old Jun 25, 2002 | 12:22 AM
Superdave's Avatar
Superdave
MonkeyBoy, The oil pressure sending unit is located on the very rear of the block behind the intake manifold and to the right a bit, as you would be looking at the engine from the front. It will have a single wire hooked to it.
Old Jun 25, 2002 | 10:04 AM
MonkeyBoy's Avatar
MonkeyBoy
Thanks to both of you for the info.
Old Jun 26, 2002 | 10:28 PM
794wd's Avatar
794wd
herothc2003
Mar 29, 2009 08:13 PM
Darthange
1997 - 2003 F150
Dec 9, 2008 10:57 AM
jbailey888
Oct 22, 2007 01:32 PM
92EBnTX
1978 - 1996 Big Bronco
15
Jun 7, 2005 02:48 AM
herby1
Apr 17, 2003 07:37 PM
