Spark Plug reading
Old Jun 27, 2002 | 12:44 AM
MaxRaceSoftware's Avatar
MaxRaceSoftware
Post Spark Plug reading
How to read spark plugs ;
*** Mostly valid only for full-load dyno tests ,
or if engine is quickly turned-off after
finish line, and then towed back to pits,
and spark plugs removed for readings there !
Plugs, best viewed with a 10x power illuminated mag. glass
Heat Range = Ground Strap , the ground strap indicates the
heat-range of the spark plug. If the "color" of
the ground strap "changes" too-close to the ground-strap's
end, (which is above the center electrode), then the
heat-range is "too-cold" , meaning that the strap is
loosing heat too-quickly to the base-ring, and is not
able to burn-off deposits until near its end.
If the "color" of the strap changes near where it is
welded/attached to the base-ring(last thread ring),
then it means that the plug heat-range is "too-hot",
because heat is not being tranferred/cooled from the
strap to the base-ring quickly enough !!!! The strap
might begin to act like a "glow-plug", eventually
causing preignition/and/or detonation later on.
Proper heat-range is when the "color" is at the
half-way point on the strap, neither too-cold or
too-hot.
(Color= meaning the evidence of heat/or lack of heat
by the appearance dark vs lightened color of metal)
Jetting = the air/fuel mixture ratio shows up on
the base-ring (the last thread ring, it has the strap
welded to it).
You want 1 full-turn of light-soot color on the base
ring!!! If you want to tune for max. power, then you
want 3/4 to 7/8ths of a full-turn of light soot color
to show-up on the base-ring, but this is on ragged-edge
of being too-lean, but will make the most HP on most
engines. To be safe, leave it at a full turn of light
soot color.If the base-ring has a full-turn of color,
but there are "spots" of heavy build-up of "dry-soot"
on top of color, then jetting is too-rich .
NOTE> If the base-ring has a full turn of color with
some spots of heavy dry-soot, then jetting is too-rich,
REGARDLESS,if porcelin maybe "BONE-WHITE", jetting is
still TOO-RICH !!!
NOTE> Do not look at the porcelin to read jetting !!!
Porcelin = the porcelin shows up preignition/detonation,
it will not accurately reveal jetting/air/fuel ratios.
To look for the first/beginning signs of detonation,
search the white porcelin for tiny black specks or
shiny specks of aluminum that have fused to the porcelin.
When detonation occurs, part of the air/fuel mixture
explodes instead of burning, the explosion is heard as a
"metallic-knock", this audible knock is the result of a
sound shock-wave, this shock wave travels back and forth
across the clearance volume "disrupting" the cooler
boundary layer gases that cover the entire clearance volume
area,this disruption allows "more" heat to be transferred
into parts, especially, domes/piston tops,...along with the
very rapid rise in pressure like a hammer like blow, pistons
can get torched/melted sides/holes !!! With the early signs
of detonation, the shock-wave will also rattle rings causing
the tiny amounts of oil that now gets by rings, to be fused
to the white porcelin as tiny black specks, also fused as specks
are soot that was clinging to clearance volume surfaces
in the relatively "still-air" of the boundary layer.
One step beyond the black specks,will be tiny specks/*****
of alumimum coming off-pistons that will be fused to white
porcelin,....the next step to be reached is occasional pieces
of the porcelin being broken-off as detonation gets worse,ETC.
Soon after that, are holes, blown head gaskets, broken
connecting rods, ETC.
NOTE> additional signs of beginning detonation are piston
rings. By comparing ring's "free-diameter" to "out-of-box"
free-diameters of new unused rings will reveals beginnings
of detonation before much harm is caused !!! This is a result
of the above previous explanation about heat being transferred
more readily because the of the relatively insulating/cooler
boundary layer being disrupted by the shock-wave.
A piston ring is a simple spring,
when a spring is over-heated it will loose tension.
Center Electrode = the very tiny sharply defined porcelin -"ditch"
that encircles the center electrode, will also showup early
signs of preignition/detonation/wrong heat-range. Look for signs
of the ditch beginning to be filled up with melted porcelin,
you will need a 5x or 10x mag. glass.
The "Ground-Strap" = Heat Range
The "Plug's Base-Ring" = Jetting
The "Porcelain" = signs of preignition/detonation
Larry Meaux (meauxracing at mindspring.com)
Meaux Racing Heads
MaxRace Software
ET_Analyst for DragRacers (software)
http://www.mindspring.com/~meauxracing/
Old Jun 27, 2002 | 10:27 AM
airharley's Avatar
airharley
Spark Plug reading
Old Jun 28, 2002 | 01:34 PM
TorqueKing's Avatar
TorqueKing
Spark Plug reading
I just look at the center electrode. If it's white, then it's too hot, if it's black, it's too cold. If it's a nice brown color, then you're all set. Reference: Haynes Auto Repair Manual
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old Jul 1, 2002 | 02:29 PM
slikness's Avatar
slikness
Spark Plug reading
Thanks Larry, we'll use that as we analyze our newly freshened Grand Stock engine.
Old Jul 1, 2002 | 05:11 PM
MaxRaceSoftware
What i posted , will just get you into the "ball park" !
ideally, should tune engine on the dyno
DragRacing at approx 600 RPM/SEC acceleration test rate
Dirt Track Racing = 300 to 600 RPM/SEC
NASCAR = 100 to 300 RPM/SEC
and look at gains/losses in average Torque/HorsePower numbers
and fuel flow readings , etc.
let the engine show you what it wants on the dyno and the race track
Old Jul 1, 2002 | 05:15 PM
MaxRaceSoftware
i have a few spark plug pictures of what spark plugs
look like with varying jetting and heat range
they are only from dyno tests !
maybe someone could post them somewhere so others might see what i'm referring to in terms of plug reading ???
Bear River
Aerostar
Feb 18, 2010 10:48 AM
Argess
19
Aug 19, 2009 06:40 AM
Petepope
1997 - 2003 F150
Sep 15, 2006 09:30 PM
Barnstang
20
Dec 29, 2003 06:55 AM
MaxRaceSoftware
Jun 28, 2002 12:30 PM
