Alright guys, I have the A/C amp draw problem solved. Thanks to everyone who helped. Now I need to know how to reset the check engine light. Thanks in advance.
Unhooking the negative battery cable or pulling the ECM fuse for 20 minutes will completely clear the memory.
What this means: You lose the CEL and the associated codes (unless they appear again), but you'll need to let your truck re-learn everything. The only different thing you should do when you start it next is let it idle for a full minute to re-learn it's idle.
