wipers quit....
wipers quit....
I am sure this is already on here but my slow azz dial up SUX!!!! truck is a 90 f-150 wipere are delay. Had needed to give a LIGHT tap under switch to get low speed and delay and high speed has never been fast since I owned it. Turned on the switch last light and got a relay cycling sound similar to a high speed turn signal click.... What went out?
Thanx in advance....
Brent
Brent
Brent
Brent
Getting at the black box isnt as hard as it sounds. It disassembles fairly easy so you can have a look at the circuit board. You may need a magnafying glass to see the hairline crack in the solder. It would probably be worth your while to at least check this before throwing parts at the job imo. I'll be happy to get some pics if it will help you out.
B
B
the clicking is just the relays going, pretty normal, my wipers are slowing up and sometimes the motor wont engaugge unless i force it to or move the switch back and fourth a few times... not always fun, especially after you just sprayed the window with the washer fluid and then realize the wipers arent working.. NOT too fun... ive been told to replace the core or to grease the linkages
