hard to start?
Old Jul 6, 2007 | 08:54 PM
N8N's Avatar
N8N
hard to start?
Just picked up a '93 F150 with a 300 last week... runs great except for one problem. When starting dead cold, it will catch then either die or almost die. Also when pulling away from a stop it will bog a little bit. When warm it runs fine. Is there a common cause of this, or should I just wait for my FSMs to arrive?
thanks,
nate
Old Jul 7, 2007 | 05:23 PM
Ranger GT2's Avatar
Ranger GT2
Have you tried to see if the computer has stored any codes? Is the check engine light on? Sounds like it might be running a little lean during the warm up period.
Have you checked to see if the plate inside the throttle body and just behind it is dirty?
Old Jul 7, 2007 | 08:51 PM
N8N's Avatar
N8N
No light, don't know how to check for codes (ordered manuals a couple days ago) have not inspected anything that requires disassembly yet. I just got the truck about a week and a half ago, so I'm still in that "getting to know you" stage - today for example I cleaned up the battery and cables and also the front ground points and fixed the ashtray (PO had removed it and cut the wires to the lighter - don't know why)
Is the throttle body easily cleanable? I know that some TB's don't like being cleaned with carb cleaner, is this one of them or can I go ahead and spray away?
nate
Old Jul 7, 2007 | 08:56 PM
v10squirrel's Avatar
v10squirrel
i suggest replacing the plugs, wire,cap,and rotor and see what happens
Old Jul 7, 2007 | 09:54 PM
Ranger GT2's Avatar
Ranger GT2
Some carb cleaners should not be used. They make a throttle body spray that is safe for sensor and such. Checking plugs and tune up items like v10squirrel suggested could make a big difference also.
