Most likely a stupid Question
Old Jul 24, 2002 | 10:31 AM
jokerx55's Avatar
jokerx55
How do you put the Harmonic balancer/Vibration Damper back on, Does it need to be preesed, is there a tool, or do you use a flat object to hammer it back on?? Thanx for any input.
Old Jul 24, 2002 | 10:34 AM
georgedavila's Avatar
georgedavila
Use an installing tool. Most places rent them.
And the only stupid question is the one not asked.
Old Jul 24, 2002 | 10:53 AM
rabidranger's Avatar
rabidranger
I just put the H/B on as far as I could, then I threaded a bolt into the crak on my 302 with a stack of LARGE washers and tiightened it down. I threaded a bolt into a spark plug hole to use as a piston stop also. DO NOT USE A HAMMER! You could damage the crank bearings if you hammer on it too hard or too long. The installation tool the above poster described is pretty much the same technique I described.
Old Jul 24, 2002 | 03:15 PM
TorqueKing's Avatar
TorqueKing
With a little creativity, you can use the balancer puller, I actually have a picture of me doing this, but I can't figure out how to post it. It'll ruin the puller tool, but if you rented it, they won't care. TK
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old Jul 24, 2002 | 09:39 PM
georgedavila
Lieutenant Daly, please pardon my disagreeing with your experience and recommendation to intentionally destroy another man's tools for your own convenience. As you are in training to be a leader of men in what could be life and death situations, I would hope you direct your future responsibilites in a more responsible manner. Do not take my message as a comment on your mechanical and technical abilites, I read your postings and learn from them.
My apologies to the forum.
Old Jul 24, 2002 | 09:42 PM
Brian460's Avatar
Brian460
I second Rabidrangers motion.
Old Jul 24, 2002 | 10:14 PM
TorqueKing's Avatar
TorqueKing
What I mean by ruin is that the top few threads on the bolt will be smashed, but there's no way that anybody will ever need that part of the tool again. I've done it twice, and used the same tool. I don't like intentional destruction of tools either. As I returned it, it was still perfectly functional, but it looks rough. I don't know about you, but I have no problem asking my tools to perform to their limits. No harm, I even work part time at the store I borrowed it from, and nobody has a problem with it. So in conclusion, it "roughs it up," not actually ruins it, because the full function is retained. TK
Old Jul 25, 2002 | 11:13 AM
georgedavila
I use my own tools to their capacity. If it goes beyond that, to me it's obvious that I'm not using the right tool for the job.
Old Jul 25, 2002 | 12:09 PM
TorqueKing's Avatar
TorqueKing
adapt and overcome. You can't just run to the parts store at 11:00 pm, so some times you have to do what you have to do to make deadlines. TK
Old Jul 26, 2002 | 01:54 AM
Superdave's Avatar
Superdave
[updated:LAST EDITED ON 26-Jul-02 AT 02:55 AM (EST)]joker, what motor are you working on? On a 460, 400, 351M I know for sure uses a 5/8" fine threaded bolt. I made my own installation tool with a chunk of 5/8" fine threaded allthread, a grade 8, 5/8" fine threaded nut and the washer from the dampner bolt itself. I don't have $10.00 in it. And have used it many times. Don't ever beat a dampner on with a hammer.
Old Jul 26, 2002 | 10:44 AM
jokerx55's Avatar
jokerx55
It's a I6. I think i'll try the washer trick or get the assembly tool.
Old Jul 27, 2002 | 10:43 AM
flyboy2610's Avatar
flyboy2610
Every time I've ever had to put one on, I just start it by hand as far as I can, then use a large washer and the crankshaft bolt. It goes right on.
Old Jul 28, 2002 | 09:16 AM
georgedavila
