System check???
Old Jul 9, 2002 | 05:13 PM
aintskeered's Avatar
aintskeered
System check???
Is there any way, other than running to the garage and hooking it up to the computer, to check the reason why I'm getting a Check Engine Light?? I get the light, and when I hit the gas, the truck hesitates, then jumps. Any suggestions?
Old Jul 10, 2002 | 09:38 AM
TorqueKing's Avatar
TorqueKing
System check???
Go to AutoZone, and have them retreive the code, it's free.
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old Jul 10, 2002 | 07:41 PM
Franklin2's Avatar
Franklin2
System check???
You can use an analog voltmeter.
Old Jul 29, 2002 | 05:58 PM
aintskeered
System check???
Went to Auto Zone, Got codes "33" and "63"
33 is EGR Sensor bad
63 is Throttle Position Sensor bad
Replaced both for a total of $45
Everything works fine now!!! Thanks alot for the AutoZone tip!!
Old Jul 29, 2002 | 10:44 PM
the law's Avatar
the law
System check???
