Need help quick
Old Jul 6, 2007 | 12:32 PM
tndiesel's Avatar
tndiesel
Need help quick
I'm trying to get this done before 3 p.m. this afternoon. Flushing and refilling cooling system. Which one of these is my drain plug and what kind of tool do I need to get it out? In bottom left of pic that is a little bit of my oil filter you see.
Thanks!
Old Jul 6, 2007 | 12:34 PM
tndiesel's Avatar
tndiesel
This is my drain plug for the Rad. right? Can I also disconnect the hose that comes from the plastic container where it connects on the bottom of the lower Rad hose for more drainage?
Old Jul 6, 2007 | 12:36 PM
bkcowboss's Avatar
bkcowboss
take the bottom hose off and move out of the way
Old Jul 6, 2007 | 12:43 PM
tndiesel's Avatar
tndiesel
What about the drain plug from the block, I really need to know how to do this, which one and what tool.
Old Jul 6, 2007 | 03:20 PM
m14dan's Avatar
m14dan
I think the block drains were a 5/16 square socket. I think it's called a drum socket or something. It's been a long time since I bought mine. See if a 3/8 drive ratchet fits it. If not then it's probably the 5/16. That should be the block drain though. Usually there is one on each side. I've seen some that don't though. It is a good idea to drain from there if you can. You'll get a lot more out. Still drain what's left in the radiator though. Put a little teflon thread sealer on the threads of that plug when you have it out too.
Sears had a set of those square sockets last time I looked. I'm sure napa would too.
Old Jul 6, 2007 | 03:24 PM
Cuda_jim's Avatar
Cuda_jim
It's the top plug in your 1st picture. USe a ratchet with an extension, the square drive is all you need (no socket). BTW: there is another one on the other side of the block but the starter is in the way.
The next picture is your radiator drain.
Old Jul 6, 2007 | 03:32 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
TJ put this foto in other post for you.
http://good-times.webshots.com/photo...99659029SQTvvI
Old Jul 6, 2007 | 03:52 PM
tndiesel's Avatar
tndiesel
Yes I found the one over the starte and of course it is regular bolt. It is virtually impossible to get to without removing the starter though!
Old Jul 8, 2007 | 10:22 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Thumbs up
RÖENTGEEP, Great picture. As they say a picture is worth a thousand words. REP points sent.
Old Jul 9, 2007 | 01:29 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Red face
Thankjs Plowhand, but I should decline the REP points and send them to TJ because is from his album.
Old Jul 10, 2007 | 07:37 AM
plowhand's Avatar
plowhand
Playing in the Dirt
RÖENTGEEP, yes it is from TJ's album, but you took the time to find it and post it for him, the points are yours. Enjoy.
Old Jul 10, 2007 | 12:02 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Well. mercy
