need help!!!
Old Jul 6, 2007 | 10:44 AM
farmlucki's Avatar
farmlucki
need help!!!
I went out this morning and pulled some codes from my truck and what I got were: P1139, P381, and a P470. I lost my book for my superchip to tell me what thery mean so if someone could help me out it would much appriciated. Thank you! Also the truck seemed to run fine before nut I went and uploaded the tow safe on it, will still run ok??? Thanks.
Old Jul 6, 2007 | 10:50 AM
fbilly420's Avatar
fbilly420
P1139-water in fuel indicator circuit malfunction
P381-glow plug indicator circuit malfunction
P470-exhaust back pressure sensor cicuit malfunction
hope this helps
Billy
Old Jul 6, 2007 | 10:51 AM
farmlucki's Avatar
farmlucki
thank you, how do I fix them??
Old Jul 6, 2007 | 10:57 AM
fbilly420's Avatar
fbilly420
i am not sure on the 1139 or the 381
but the 470 the sensor is mounted on the front of the engine with a tube that runs over to the pass side exhaust manifold and the tube will get plugged and gum up the sensor, you can remove the tube and sensor and clean them out, i had the same problem on my truck about a month ago and just cleaning it helped me. give it a try to remove the tube just need a 17mm wrench.
Old Jul 6, 2007 | 10:59 AM
fbilly420's Avatar
fbilly420
on the p381 check fuse #19 it is for the wait to start indicator on the dash.
does the wts light come on or stay on?
Old Jul 6, 2007 | 11:48 AM
farmlucki's Avatar
farmlucki
the wts comes on and and goes off as normal. Can some one send me a picture of the tube and the senser so I can see it. Thank you
Old Jul 6, 2007 | 12:10 PM
cjcocn's Avatar
cjcocn
http://guzzle.rbmicro.com/ebps.html
Pics and instructions are available via the above link.
