Sponsored by: Kumho
Load rating versus maximum weight
Old Jul 6, 2007 | 07:42 AM
WEFITE4U's Avatar
WEFITE4U
Hopefully someone can help me out.
I am looking for a 38" tire for my F250. It came with E rated tires. I can find tires that have a max weight of around 3500 pounds but are only C rated. Can someone tell me what the difference is?
Thanks
Old Jul 6, 2007 | 09:51 AM
aurgathor's Avatar
aurgathor
C rated tires are rated for only 50 psi and have less plies than E rated tires. Don't worry much about rating as long as you have the load carrying capability.
Old Jul 6, 2007 | 10:04 AM
khadma's Avatar
khadma
Carpenter Local 745
What size are your current E rated tire? Are they near stock size aftermarket tires?
Old Jul 6, 2007 | 12:15 PM
WEFITE4U's Avatar
WEFITE4U
My current tires are stock E rated tired. I am lifting and putting on bigger tires. I dont tow much, and i i will never tow anythign extremely heavy. Nothing bigger then a car trailer so maybe 6000 pounds.
Old Jul 6, 2007 | 05:44 PM
rebocardo's Avatar
rebocardo
BTW: I agree with post #2
If you are buying tires rated for 3500 pounds each (basically a D range anyways) that is more then enough for your truck. 3500 x 2 = 7000 for one axle and your truck probably weighs just about that. So, 3500x4 tires=14,000 pounds. That would handle your truck fully loaded and then some.
C rated tires are generally 3 ply and 50 psi (as previously mentioned).
I wouldn't worry about it, just inflate them towards the max when towing.
Old Jul 7, 2007 | 09:00 AM
WEFITE4U's Avatar
WEFITE4U
Thanks for all the info. I guess i will go with the 38x15.5x20 Baja Claw Radials. They are listed at about 3500lbs max weight and have a D load rating.
Last edited by WEFITE4U; Jul 7, 2007 at 09:01 AM. Reason: entered incorrect information
my996duc1
All Things Towing
13
Jan 9, 2012 06:08 PM
my996duc1
6.7L Power Stroke Diesel
50
Jan 1, 2012 12:56 PM
Ultraute
Sep 9, 2004 08:30 AM
FarmApe
All Things Towing
Mar 19, 2004 03:09 PM
Dewman
Dec 20, 2003 12:49 PM
