Oil Change Miles/months??
Do these Heavy Duty 15/40 Diesel engine oils (I use Rotella T or Delo) loose viscosity over time as well?
Should I do something like 5000 miles or 4 months whatever comes first??
Thanks,
JB
When a vehicle sits and is not driven much or driven for short trips the moisture and acids build-up in the oil and after awhile the oil additive package is no longer able to neutralize the acids that build-up.
I wish I could find the article I read recently where a Sr. Ford person commented on Ford's lack of using these oil life monitor indicators like the others are going to, and his response was simply that they keep it this way as a convienience to their customers.
For what it's worth, I change mine based on miles only, I don't drive enough to do it based on time!!
My $.02 worth...
Befor I buy another vechile I have to have the budge to change the oil 3 times a year. I'm happy when I dont have to change it but every 6 months, thats money in the bank for me. I too wish we had a timer on our trucks. When pulling hay for hire I carry my 3 trailers. I drop off an empty and pick up a loaded trailer. I've only been pulling goosenecks since last october and I havent found a faster way to unhook and get up under another one. It takes me about 15 minutes to get out from one and pull of with another one. The biggest part of the 15 minutes is the truck idling while I jack up/down the trailers and hook up power.
I use miles/months which ever comes first and I pray its months.
As another note, my experiences lead me to believe that the anti-foaming agent of any oil used is a keep factor in deciding when to change.
I continue with the Rotela T 15-40; seems to be causing me problems after 5k on a regular basis, as my 6.0 has the surge/stumble/smoke issue that many are complaining about. Anytime I have had the stumble problems, or particularly stalls of the motor coming off he interstate after running for say 5-6 hours steady with load, an oil change has cleared the problem up. So I gave up chasing EBP, EGR and other things and focused on the high pressure oil circuit, the injectors they operate, and foamy oil in screwing up precise injector operation, not to mention a PCM that is trying to overcome the problem of foamy oil.
I haven't found a lot of information yet on exactly what I'm talking about, but me thinks that keeping the oil in tip top shape is the most important thing you can do for a 6.0
We're using regular old motor oil as a hydraulic oil in the high pressure circuit for the injectors; I would like to see some evidence that Rotella T can function in this capacity after miliage, time, heat, contaminants, and particlularly dilution.
I'm certainly no expert, I'm just looking to keep mine together long enough to pay for it.
https://www.ford-trucks.com/forums/6...-additive.html
I did a change five days ago that now has close to a thousand miles on it. I used the FL-2016 filter, and Rot-T 15-40, but I added a quart of Lucas Pure Synthetic oil stabilizer. at 300 miles my 04 6.0 was stumbling, surging, and puffing.
I pickup up a 10k trailer and things went from bad to worse; 2100 was the magic rpm for a cough and a puff of black smoke.
I stopped at an Advance Auto and ran the mickey mouse diag and got three codes
P0404 EGR Flow
CKT Range/Perf
P2285
Injector Control
Pressure Sensor
Circuit Low
P2287
Injector Control
Pressure Sensor
CKT Intermittent
The Rot-T is CJ-4 Compliant.
The EGR was replaced at about 25k after I had the truck a few months along with a PCM reflash, but the oil was changed at the same time.
Anytime I want to the beast to run well again, I change the oil. I think the Lucas was a bad idea. I'm going to change it again right now with another FL-2016 and 15qts of Rot-t 15-40.
I'll fill you in on the results in a few hours.
Thanks again.
In your case the OCI should be every 5k miles even if that means once per week if you drive alot. The 6.0 unlike the 7.3 (or other engines with similar injector systems) uses a much higher oil pressure to fire the injectors. This leads to rapid shearing of the oil. This rapid shearing of the engine oil causes increased aeration and foaming of the oil resulting in pressure loss to the injectors do to cavitation at the HPOP, which leads to the poor performance you have experienced along with shortend injector life. Oil additives do not help extend OCI and in many cases cause oil related problems do to the additive haphazardly changing the chemistry of the oil.
There are many posts on this subject and many UOA results both here on FTE and at the BITOG website. Fresh clean oil of the proper API rating and viscosity for your driving conditions is very important for proper performance and injector life of the 6.0.
Thus I may be looking at replacing injectors now at 105k.
Thanks again.
