Cluster ground
Old Jul 5, 2007 | 02:23 PM
mudslingur's Avatar
mudslingur
Cluster ground
Where dose the instrument cluster ground?I need to clean it up or something,because my gauges are going haywire and then they start working again,its just a cycle that goes on.
Old Jul 5, 2007 | 11:15 PM
dionysius's Avatar
dionysius
Pull the console. Connect a ground wire between a good chassis ground and the screw retaining the Voltage Regulator to the back of the cluster.
Ohm out the traces on the flexible circuit board. Clean and loosen / retighten the nuts holding on the gauges.
Replace the console having inspected and cleaned the obvious stuff including the connector.
