Road Trip From Hell, Top this one!!
What's the procedure for adjusting valve lash. On my old 56 and 58 Chevy's, I recall running the engine with the valve covers off and adjusting the rockers to get the hydraulic lifters centered in their working range using a feeler gauge. Even with solid lifters on my race engines I always did a double check with the engine running. So how do you make sure the valve train is working ok on a diesel since you can't check it with the engine running?
. Being innovative comes easy, that is how I am even in business to begin with. But holy crap that was too much all at once. Right down to the flat tire. I left my bottle Jack at home, so to get the wheel off the ground I had to use my leveling blocks and stack those high enough to drive my front axle on to get the rear wheel off the ground. Man I know these problems are not normal, but it sure challenges my loyalty. Wife to me, and me to the truck.....Ernest- I think you may be on to something there. I am doing to research on specs now, and trying to figure out if there is someway I could be losing some lift from my valves due to the stuff you mentioned. With the self adjusting lifters, I am not sure how, but who knows. It could even have something to do with the oil flow not being adequate to keep the lifters pumped up under load. My trip to denver at altitude made it clear that I am lacking low RPM airflow. While towing I had to turn my chip down to stock, wait for the truck to get moving, then turn it back up again. Otherwise the truck would just sit there and spew clouds of Black smoke. Once moving, then it performed more or less normal.
. I am good at fixing stuff, and even better at breaking it which gives me a pretty well rounded ability. For example, so far on my truck I have done the following:Replaced both Front hub assemblies,
Installed 05 nose and badges
Dynomatted complete inside, including doors
Installed DVD NAV system
Overhead DVD player
10k mod
Manual TC lockup
Replaced ALL tie rods
Replaced Steering Gear Box with RedHead Unit.
Installed Tuff Country leveling kit
Removed Tuff Country(threw it away) and installed Revtek Lift Kit
Busted Rear Spider Gear- Installed Detroit TrueTrac
Installed 4.56 gears in Oklahoma
Replaced Transmission. 3 Times
Replaced Motor. 3 Times
Replaced Turbo. Can now R&R turbo in less then an hour.
Replaced All U-Joints
Replaced Front Axle, Passenger Side
R&R Front Axle bearing inside bearing assembly
Replaced busted Flywheel while on a road trip.
In Tank Mods
Custom Fuel System
Replaced all sway bar bushings
Removed all upholstery from seats and washed, then reinstalled
Bunch of engine stuff
That just off the top of my head, I am sure I could go through my maintenance book and find some more stuff I have done and forgot. So if there is anyone in the area who wants a helping hand, or my experiance with a particular product, let me know!! Chances are I have done, broke it, or thought about it.
A few notes, gloves work well on the stock jack handle and I always have a pair in the truck. Of course I'm wearing a bandaid now but for a stupid XBox360 ring of death light repair mod I'm currently still trying to repair. $400 POS. My son's item so no emergency.
IIRC there is a baro sensor. I think yours is not located in the PCM like the later 7.3s and I'm beginning to wonder if your higher altitude probs are not from a faulty unit there.
I don't think there is a lash adjustment on hydro lifters but it has been a long time since I dealt with that. It should be torque and go. You could have a bad lifter though, but I have never run across that, doesn't mean it can't happen. Sounds like it pumped up well though so your hardware must have come loose, just my guess. Glad no damage.
I am looking at a 2k round trip here in about a couple of weeks. Don't like to see this kinda thing. I still havn't decided on whether to take the 150 or my 350.
FN ,my hat is off to yah....Country
