Headers?
Old May 15, 2002 | 09:23 AM
woodbosky's Avatar
woodbosky
Headers?
I was wondering which headers would be good for me, Ihave an 84 bronco with a rebuilt 31W. It has a mild cam, but nothing too crazy. Any suggestions would be appreciated.
Old May 15, 2002 | 09:33 AM
TorqueKing's Avatar
TorqueKing
Headers?
ceramic coated Dynomax headers, they're like $200, and your underhood temps will be amazingly low, and you'll pick up a good bit of performance, fuel milage, and actually lower your emissions at the same time.
The TorqueKing
Old May 15, 2002 | 04:06 PM
RonBo's Avatar
RonBo
Headers?
I used Motorsports shorties. They have a good flange thickness to prevent warpage, and they're stainless. The main problem with them is the usual with headers, you need to retorque the bolts on occasion to prevent the gasket from leaking. The headers are direct bolt-on replacements.
I don't know how ceramic coated headers would reduce emmissions on your engine. The NOx, and CO are created from the combustion process at idle and part throttle. I do believe the underhood temp reduction claim.
Also, don't expect giant gains in performance from headers. They do not increase horsepower and torque, they will reduce exhaust system losses. You may feel the improvement, but don't be disappointed.
Old May 15, 2002 | 05:24 PM
shazam's Avatar
shazam
Headers?
< I don't know how ceramic coated headers would reduce emmissions on your engine. The NOx, and CO are created from the combustion process at idle and part throttle. I do believe the underhood temp reduction claim.>
OK how this works is it keep the heat in the pipes which help burn more gasses on it's way to the cats. which in turn will give you a cleaner reading at the tailpipe.
Old May 17, 2002 | 12:36 AM
harley's Avatar
harley
Headers?
I just put a set of Dynomax long tube headers on my 94 F-150. Check out Summit Racing for header bolts. I ordered a set that have locking clips so the bolts will not back out.
Bob
Old May 17, 2002 | 07:40 AM
slikness's Avatar
slikness
Headers?
Those ceramic coated headers are awesome and it does reduce your underhood temps dramatically. You can darn near grab hold of one of them headers and not get burned. Like Shazam and TorqueKing said it will help with emissions and opening up the exhaust with a good set of headers, plus decent pipe the rest of the way back will free up substantial ponies for a good seat of the pants difference....and it will sound sooooo sweet..
Old May 17, 2002 | 12:23 PM
Ford 4 Life's Avatar
Ford 4 Life
Headers?
What about sound? How much louder are they?
Old May 17, 2002 | 12:26 PM
TorqueKing's Avatar
TorqueKing
Headers?
The sound will most greatly depend on what you put after them, but I promise you it'll be louder, especially if you just don't put anything behind them. Your neighbors will hate you for it, but it's worth doing once in a lifetime.
The TorqueKing
Old Jul 29, 2002 | 05:28 PM
JJH's Avatar
JJH
Headers?
Hey where did you find the Dynomax headers at. Did you have to order them from a catalog?
Old Jul 29, 2002 | 11:28 PM
TorqueKing's Avatar
TorqueKing
Headers?
call Jeg's or Summit, I like Jeg's because their tech support is open 24 hours, they can tell you if they have them in stock. Their number is 1-800-345-4545. Oops! did I just spit that out off the top of my head? I've never ordered from them before (haha)! Anyway, give them a call at 4:00 this morning, they'll be there. The real reason why I prefer Jeg's is due to the amazing kindness of the Coughlin brothers. I have toured Jeg Jr's entire trailor at an NHRA event, he was so impressed that I was a fan of his. Give 'em a call! TK
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old Jul 30, 2002 | 06:26 AM
Brncomtb's Avatar
Brncomtb
Headers?
What do yo uguys think about the Headmen Elite Headers? I have been thinking about getting those for my 302.
Old Jul 30, 2002 | 08:15 AM
georgedavila's Avatar
georgedavila
Headers?
Dyno tests have shown that shorty or tri-y headers offer little, if any performance improvement over a stock exhaust manifold. Most people who install them feel a 'seat of the pants' improvement because in most cases the installation has included a less restrictive exhaust system behind the headers and a different sound.
If you're after tangible performance increases, use full-tube headers that have at least 3-4 feet of length to aid in scavaging gasses from the exhaust ports. They allow the exhaust 'pulse' to get a running start before the next one hits it.
Old Jul 30, 2002 | 03:43 PM
HotWhlz85's Avatar
HotWhlz85
Headers?
Couldnt be more pleased with them. I have a set on my 351W in an 85 F150 4x4. Fit couldn't be better, easy to install, and they look awesome. Mine are jet hot coated (I think all the elite's are). The only installation issue I ran into was having to drop the front driveshaft to hook the driver's side up.
Ron
Old Jul 31, 2002 | 11:37 PM
Brncomtb's Avatar
Brncomtb
Headers?
Thanks Hotwhlz. I hope cause i have a smaller engine i won't have the same clearance issuse and can leave everything intact.
JON
Old Sep 1, 2002 | 11:15 AM
1rocket's Avatar
1rocket
Headers?
I recently added Mac equal length "shorty" headers. These were the only equal length headers with OEM fit & fittings I could find. From back in the day I know equal lentgh are better than shorties that are not equal length. No shorty works as well as full headers, however.
The Mac headers went on pretty easy, I wish they were ceramic coated, came with a good quality gasket and I used locktite on the bols... so far no leakage.
These sound and perform awesome with the Gison catback system. I'm finding with these bolt on mods, that everything is incremental: the chip gives a little, the catback & headers some, low temp thermostat... now with what I've done my truck is very noticablly quicker... and man does it sound sweet when you roll on the accelerater!! A whole lot more fun to drive.
Rob
1996 Ford Bronco, 5.8L:
-Done:Hypertech III,Powerstat, K&N FIPK,cooler TBody bypass,Mac equal length headers, Gibson cat-back, Taylor wires, Urethane bushings, BF Goodrich TA's, Roadmaster active suspension, Nozzle lights, Euro taillights
-ToDo: MSD Coil, Hypertech cap & rotor, Edelbrock performer intake manifold & 56 Tbody, Granetelli MAF
