93 ranger brake lines
Old Jul 4, 2007 | 12:20 PM
redneck1377's Avatar
redneck1377
I am new member on this forum, but been a visiting for a while, my brake line has split in a number of places and need replacing, what is the best way to remove the fittings from the wheels and junction block when they are corrosive, can they be heated without causing a fire or damage the seals or rubber comporent
Old Jul 4, 2007 | 01:05 PM
Ultramagdan's Avatar
Ultramagdan
Welcome to the site!
You will want to post your question in the tech forums since this one is used for introductions. Just click on the Forums tab at the upper left and scroll down the list. You can try the Ranger forum but you can get help in the Brakes forum to. Here is the link: https://www.ford-trucks.com/forums/forum64/ With that said I would not use heat on the connections at all. Use a good penetrating oil and a good set of wrenches and you should be able to get them off.
Also stop in your state chapter, it's located at the bottom of the Forum list.
Old Jul 4, 2007 | 03:08 PM
redneck1377
many thanks, what section is best to answer question about wd40 , what is a good brand of penetrating oil
Old Jul 4, 2007 | 03:19 PM
Ultramagdan
I like this:click here
I would still try the Brake forum link I provided above. BTW, you will find a lot of help in the Ranger forum.
Dave Manker
New Member Introductions
Nov 8, 2007 04:39 PM
seagypsy
Aug 8, 2007 04:50 PM
f250scott
Aug 6, 2007 09:22 PM
wreckedtruck
Feb 10, 2007 10:16 AM
Chris Morrison
Jan 14, 2007 02:23 PM
