synthetic oils
Old Jul 4, 2007 | 09:24 AM
mullins2000's Avatar
mullins2000
synthetic oils
is anyone running synthetic oils for motor,tranny,rears, ect. if so what do you suggest for brand and weight and as far as motor what change interval are you changing the oil. thanks for any info
Old Jul 4, 2007 | 10:05 AM
Lonewolftx's Avatar
Lonewolftx
Wink
Do a search on this as it has been discused many times. The answer is yes except for the tranny as it requires Fords special tranny fluid from the dealer.
Super08's Avatar
Super08
For the engine 5w40 syn is what will cover the broadest tempature range. People here use it for towing as well with no problems. Brand wise the the most popular are Rotella T syn and Mobil 1. I am up in Canada and Use PetroCan Duron Syn as it is easier to get. Be sure to use OEM type filters only, they are made by Racor.
Old Jul 4, 2007 | 11:26 AM
Kep4's Avatar
Kep4
Jäger
Your profile shows 04 F250 and you're posting in the 6.0 forum so we'll assume that's what your question is about. You may want to go into 'User CP' and add your trucks specs so we can assist you better.
Mercon SP is the only transmission fluid which can be used in the Torqshift trans in your truck. It's not yet licensed to be made by other companies so that's the only choice right now.
I use Mobil 1 75W-140 in the Sterling 10.5 rear axle and Mobil 1 75W-90 in the Dana 60 front axle. If your truck is 4wd then it has a Dana 50 front axle but would use the same weight axle lube.
I use Mobil 1 trans fluid in the NVG transfer case.
I'm currently running Rotella T syn as Super 08 mentioned in his post. I'll change it at 5,000 miles since I tow a heavy trailer the greater percentage of the time. Super 08 also gave excellent advice regarding only using Racor made/licesned oil filters. Do not use will fit as they don't fit! Racor, Motorcraft and Fram are good.
Check out FTE site sponsor Diesel Filters Online for good deals on 6.0 and Torqshift filters and Mercon SP trans fluid.
www.dieselfiltersonline.com/Ford-6-0-Liter-Turbo-Diesel-Truck-Filters.aspx
Old Jul 4, 2007 | 11:43 AM
WishIhada7.3's Avatar
WishIhada7.3
Actually amsoil has a tranny fluid that meets the Ford mercon sp standards/rating.....It is to my knowledge the only fluid other than ford's that can be used in the tranny....
Also amsoil makes a severe duty 75w110 gear lube that is a bit thinner and should help with MPG.
Rest assure anything you get from amsoil is top notch....dont listen to there ad slogans but talk to the customers who have used it for 3-400 hundred thousand...But with that said I dont use there Motor oil nor do I/reccomend to others to run ANY!! oil longer than oem reccomendation's with out a OA.
Old Jul 4, 2007 | 01:58 PM
blackhat620's Avatar
blackhat620
Originally Posted by WishIhada7.3
Actually amsoil has a tranny fluid that meets the Ford mercon sp standards/rating.....It is to my knowledge the only fluid other than ford's that can be used in the tranny.....
Sorry but this is NOT true. NO Transmission fluid can meet both Mercon/MerconV and Mercon SP standards. The two fluids are not compatible and not interchangeable. Their chemical properties and charactieristics are different. The Kinematic and Brookfield Viscosities are substantially different for one thing. Also Ford has not licensed Amsoil or anyone else to make Mercon SP ATF.
Unfortunately this is some more bad one size fits all marketing from Amsoil.
Also it cost alot more than the OEM Motorcraft Synthetic Mercon SP.
Old Jul 4, 2007 | 02:01 PM
mrxlh's Avatar
mrxlh
I will say this about the Amsoil tranny fluid, Why? As the Motorcraft SP is already a full synthitic, and has held up extremely well. Amsoil is more expensive, and if you read the fine print, you still have to change it at the recommended Ford service interval.
Old Jul 4, 2007 | 02:05 PM
blackhat620
The OEM Motorcraft Mercon SP is Synthetic.
The rear axle from the factory comes with Synthetic 75W-140 gear oil. FYI the front axle in all SD since mid 2001 is a Dana 60.
Old Jul 4, 2007 | 02:06 PM
blackhat620
From the factory the Transmission and Rear axle come filled with Synthetic fluid.
You can use any properly rated Synthetic fluid in the Front Axle, Transfercase and Engine that you like, and many people do.
Old Jul 4, 2007 | 02:51 PM
WishIhada7.3
I never said it was compatible with mercon/mercon v but amsoils site does...they also claim it is able to be used where mercon sp is required. just because ford did not license them to make it doesnt mean they didnt find a way around it...amsoil would not reccomend the fluid if it caused damage or didnt do the same thing as SP...alot of people dont like amsoil products here but they make good oil PERIOD....they have been around for 35 years...BUT im not promoting them just telling the guy there are other options out there...it is not bad info if you think so that is YOUR opinion. But however i do think there add slogan about the extended drain intervals off the bat are a bad idea because you should get a OA but then again when people tell you they have 250-300k on there motor and have been running amsoil since day one something must be right.
Old Jul 4, 2007 | 02:59 PM
Btravelen's Avatar
Btravelen
The topic of another post awhile back was whether SP was synthetic, or not. While I thought that it was, I could find no documentation that Mercon SP is synthetic. Can anyone post a link or other evidence that it is?
Take Care
Old Jul 4, 2007 | 03:01 PM
mrxlh's Avatar
mrxlh
Wish, not trying to start an arguement or rehash 59 pages of amsoil debate. My principal stance is it comes from the factory with full synthetic, so you are gaining nothing by making a lateral move to another synthetic. If it were a semi syn, or a regular conventional trans fluid, I would agree with you. In the case of the torqshift, it is just not the case, especially if you go and look at Jeffs blackstone report he did on his mercon SP.
Old Jul 4, 2007 | 03:11 PM
WishIhada7.3
thats fine i will be doing mine with mercon sp but i was just throwing the other info out there.
Old Jul 4, 2007 | 03:18 PM
Btravelen's Avatar
Btravelen
Take Care
I realize it's not exactly on topic, but is it 'full synthetic' just because you say so? I spent a bit of time looking, but didn't find any evidence of this.
Take Care
Old Jul 4, 2007 | 04:02 PM
blackhat620
It is Not Opinon, it is fact Mercon/MerconV and Mercon SP have different chemical properties & characteristics. You cannot have both a Mercon/MerconV and Mercon SP oil in the same bottle as they are different. It is no different than saying they have gas & diesel in the same bottle and can be enterchanged between a diesel and gas motor.
For one both the Kinematic and Brookfield viscosities between Mercon/MerconV and Mercon SP are significantly different and are not interchangeable, there are other chemical characteristics and properties that are different as well (friction modifiers being one). These oils are Not interchangeable no matter what Amsoil would like you to believe.
As far as Amsoil recommending something, their marketing department will bend the truth at will to make a buck. As far as motors running 250-300K miles, motors will do this on any engine oil. Been doing it for years with standard dino oil.
The Amsoil is not licensed by FMC to make SP, Amsoil does not meet API/ASTM ratings of Mercon SP, Amsoil ATF costs more than Mercon SP.
Please list the benefits of Amsoil ATF over Mercon SP.
