Underdrive Pulley Replacement
Old Aug 30, 2002 | 03:14 PM
h9565's Avatar
h9565
Is it worth $185 or so to replace the stock pulleys on a 4.6 V8 F150 with something like the ASP underdrive pulley set? Is there a downside to this replacement?
Thanks
Old Aug 30, 2002 | 04:52 PM
1rocket's Avatar
1rocket
Post Underdrive Pulley Replacement
>Thanks
I asked the same question to a couple guys who had pics of their truck on the Hypertech site. The potential downsides are throwing your belt or squealling because the pulleys don't align right, some or all of your accesories that are driven off the belt don't work as good as before (Charging, A/C, Heater, Engine cooling)
Answers from those that had done it were pretty much the same:
- Good bang for the buck, you could feel a slight power gain
- Headlights dim a little at night at idle, but nearly same charge on voltmeter (14) as stock when driving (mine should get full charge at 1100rpm, not at idle like stock- you gotta wonder what might happen in Atlanta or LA traffic at stanstill however?), no dead batteries reported however
- Cooloing, heater, etc. works as mormal
I just ordered an ASP crank & water pump pulley for ~$60. It will take a different serpentine which will be another ~$30.
....we'll see!?!
Rob
1996 Ford Bronco, 5.8L:
-Done:Hypertech III,Powerstat, K&N FIPK,cooler TBody bypass,Mac equal length headers, Gibson cat-back, Taylor wires, Urethane bushings, BF Goodrich TA's, Roadmaster active suspension
-ToDo: MSD Coil, Hypertech cap & rotor, Edelbrock performer intake manifold & 58 Tbody, Granetelli MAF, ASP underdrive pulleys
Old Sep 10, 2002 | 07:34 AM
h9565's Avatar
h9565
Let me know how it turns out!
Old Sep 10, 2002 | 01:37 PM
dpoelstra's Avatar
dpoelstra
unless youare running at high rpms look out for low water pump volume and lower alternator output and dead batteries. A friend of mine bought top of the line under drive pullies for his truck, ran his batteries dead and had a heating problem in the L.A. traffic due to the lower rpm the accessories operate at.
Pulled them off two weeks later and threw them away.
For lower RPM operated trucks, I think they do more harm than good.
Just a thought.
Old Sep 12, 2002 | 08:21 AM
h9565's Avatar
h9565
What truck and engine did you friend have? Do you know what brand of pulley sets he used?
Thanks
Old Sep 12, 2002 | 12:34 PM
dpoelstra's Avatar
dpoelstra
He drove a late model Chevy w/350. I am not sure of the brand, but everything he did was the best of the best. He spent a ton of money on his truck, and it was pretty cool. That's the only thing he did that he tore out.
It's just something to keep in mind. It may work for you, just check things out first.
Old Sep 12, 2002 | 11:28 PM
airharley's Avatar
airharley
huntinzombie
Mar 8, 2007 09:28 AM
04heritage4.2
3.8 & 4.2L V6
Jan 17, 2006 08:11 PM
Katmandu
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 9, 2005 08:51 PM
kenwood599
1983 - 2012 Ranger & B-Series
Jun 19, 2004 11:22 AM
Forced34795
Modular V10 (6.8l)
Apr 22, 2003 10:07 AM
