302 long rod
Old Sep 12, 2002 | 10:48 PM
Ford Truck Racer's Avatar
Ford Truck Racer
302 long rod
Figured I would post here since I did in the Windor forum too.
Anyways, I was wondering if any one has or done or seen done a 302 long rod and what pistons I would need to buy. I have found three rods, the 5.40, 5.155, and 289 rods. Which would bed the best and I would want hypertectic pistons running 9.5 to 10. compression in a 58cc combustion chamber. All help post would be appreciated.
Old Sep 12, 2002 | 11:12 PM
airharley's Avatar
airharley
302 long rod
look in the tech article section all the way at the bottom. There are a few calulators you can download to check the conrod length and piston height. Also if you aren't planning on running nitros you should be fine with those pistons.
Old Sep 13, 2002 | 12:15 PM
54_5star's Avatar
54_5star
302 long rod
Go to kb-silvolite.com and look under the Keith Black automotive line. They have quite a selection. The 5.155 rod is a 289 rod. It was also used in the Boss 302 with 3/8" rod bolts.
Old Sep 14, 2002 | 12:11 AM
pcmenten's Avatar
pcmenten
302 long rod
[updated:LAST EDITED ON 14-Sep-02 AT 01:12 AM (EST)]I have a magazine article that describes a 302 build-up with Chevy 400 rods (5.565"). They dyno'ed the combo in the article.
I don't understand why a fella would even want long rods. I know that Smokey Yunick claimed power gains with long rods, but that was with some pretty old engine technology and running at high engine speeds.
But good luck with your project anyway.
Old Sep 15, 2002 | 01:36 AM
canzus's Avatar
canzus
302 long rod
Try this web site...
http://www.angelfire.com/ar/dw42/rodratio.htm
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6, That blowed up real good...
'01 ZX2 (No Mods yet)
Old Sep 15, 2002 | 01:23 PM
86motrhead's Avatar
86motrhead
302 long rod
jbancroft
Dec 28, 2014 02:57 PM
70torino429
112
May 3, 2009 10:33 AM
BIGBRONCO93EFI
Nov 12, 2008 12:57 PM
Silver Streak
Mar 12, 2004 07:19 PM
muscletruck7379
26
Jun 3, 2003 06:01 AM
