Unidetified Ford Object
Old Sep 8, 2002 | 10:06 PM
hairball12's Avatar
hairball12
I have a 87 F250 with a 351. I am having major problems trying to get
this truck to idle right. When I put he truck in reverse or drive, it
wants to stall and sometimes will. With the truck in park it will idle high but the idle floats all over the place. While I was looking for a vacuum leak I saw this small canister on the intake manifold just to the left of the carb. It has a vacuum line going to it and a small metal arm coming out of the other side witch is linked to a lever that gose into the manifold. It looks like it opens an closes a valve in the manifold but why? Any suggestion on what might be causing the idle problem.
THANKS any help is greatly appreciated Latter
Old Sep 10, 2002 | 01:41 PM
dpoelstra's Avatar
dpoelstra
I may be wrong (as usual) but I think that that unit on the intake operates the choke on the carb.
Aside from that, I would look for a vacuum leak. I read another post somewhere, where the rough idle prob was finally discovered in a faulty power brake booster.
Never hurts to check.
Old Sep 15, 2002 | 08:27 AM
86motrhead's Avatar
86motrhead
my 86 has EFI but it also idles all over the place
if you have a power brake booster problem would you hear what sounds like an air leak near the pedal
if thats not a brake problem can u point me in the right direction about the air leak
Thanx!!!!
Old Sep 15, 2002 | 09:57 AM
airharley's Avatar
airharley
Does the air leak sound more like a sucking sound and does it change with engine rpm? If so you have a bad booster diaphram.
Old Sep 15, 2002 | 01:38 PM
86motrhead's Avatar
86motrhead
thanx for all your help
and i only seem to hear the sound when its iddling but ive never checkd at higher revs
and thanx again
Old Sep 17, 2002 | 06:26 AM
mshumack's Avatar
mshumack
winginit
70
Nov 9, 2016 11:15 PM
Thered89
Oct 15, 2016 09:18 AM
wollow007
20
Jul 28, 2016 09:17 PM
Ford59galaxie
21
Feb 12, 2016 05:29 PM
jonmark1985
Jun 25, 2013 05:53 PM
